How Can I Seal Fuel Pump Area
Old Aug 6, 2020 | 12:00 PM
JuanGarzaro's Avatar
JuanGarzaro
Default How Can I Seal Fuel Pump Area
I installed a 255LP Walbro Fuel Pump on my 2005 350z. And ever since then I’ve replaced the O Ring but it eventually starts leaking gas around the sides and it made sure I tightened it right so what can I do to seal it up good and I don’t get any leaks?
Old Aug 6, 2020 | 05:31 PM
icer5160's Avatar
icer5160
Found this article, not sure if you already followed this or not. But it appears some modification is required for a solid fit.
-Icer
Old Aug 8, 2020 | 10:59 AM
JuanGarzaro
Default Thank you for the help bro
-Icer
I had seen that article a while back I ended up figuring out my issue my O Ring had pinched itself allowing fuel to leak out I used some adhesive to lay down the O Ring let it sit for a while then carefully put the fuel pump back in and screwed it down tightly and I haven’t had an issue since thankfully!
JuanGarzaro
Jul 21, 2020 04:30 PM
Kirkster
Mid-Atlantic
15
Apr 27, 2011 05:20 AM
Torched Z
Sep 12, 2006 10:40 AM
slay2k
Dec 1, 2005 09:08 PM
LaoSiFu
Aug 18, 2005 07:07 PM
