Steering angle... tire rubbing compression rod
Old Mar 15, 2021 | 12:53 AM
malheur's Avatar
malheur
Default Steering angle... tire rubbing compression rod
Hello.
I installed inner tie rod spacer for better steering angle.
But this thin spacer only, angle is almost maxed out.
Cause inner side of tire now rubbing the Compression rod.
(Not the bump stop. Actual compression rod)
I mean, angle is only about 40 degree. (inner outer +- somewhat since Ackerman)
My wheels are not so wide. 18*9 and offsets are +22 +20mm hub spacer(just fits outer fender line).
Tires also thin enough(235/45r18).
I saw some of videos that have same cheap spacer mod and none of those have this issue.
What do you guys think my problem? Is this normal?
Old Mar 15, 2021 | 05:15 AM
travlee's Avatar
travlee
Master
Do you have another photo/angle of the car?
Old Mar 15, 2021 | 05:20 AM
malheur's Avatar
malheur
I can take some picture. Where should I look into?
Old Mar 15, 2021 | 05:25 AM
travlee's Avatar
travlee
Master
i would like to see the tire from the side (ish), also.. what kind of wheels are they
Old Mar 15, 2021 | 07:06 AM
malheur's Avatar
malheur
These are my wheels and angles with maximum turning.
Maximum I mean really. Bungee corded steering wheel to the lock that so loudly whine.
Old Mar 15, 2021 | 07:36 AM
jdmfetish's Avatar
jdmfetish
go to 235/40/18 in the front
na12uto
Aug 9, 2019 08:57 AM
StonersKnight
Oct 9, 2013 05:23 PM
phunk
May 29, 2013 03:25 PM
Row2K
Mar 17, 2011 06:25 PM
whoisthis
Feb 23, 2010 09:40 PM
