Rookie mistake
Old Apr 4, 2021 | 02:42 PM
Stico's Avatar
Stico
Default Rookie mistake
Major rookie mistake. Replacing valve covers and didn’t label order wiring harness plugs into each coil pack. Have photo of which plug goes to cylinder 6 but 2 & 4 exit the harness at nearly same location and can’t really tell which goes to which. I believe I have #6 correct, but 2 & 4 tougher to figure out. Can anyone tell me if my markups on photo are correct?
Old Apr 5, 2021 | 04:40 AM
Jim Stephens's Avatar
Jim Stephens
Let me see if I a picture for you. By the way, I thought I had mine in the wrong order because it was idling really rough like a diesel. Turns out I had a forgotten to plug in a vacuum hose on the passenger side into the plenum. Also, a plenum leak around the gasket will cause it as well. Sounds crazy, but if you put some saran wrap around the seam it will seal it up if there is a leak and will make it easy to find. Listen for some hissing.
Old Apr 5, 2021 | 04:44 AM
Jim Stephens
Here you go.. I had this same issue and luckily I found a video on you tube and was able to capture a frame of the "before" to figure it out.
Old Apr 5, 2021 | 10:12 AM
Stico's Avatar
Stico
thanks Jim....got her all back together and in the right order. Much appreciated.
sC
I DTW I
Jul 12, 2023 03:48 AM
LNVFX
Apr 30, 2019 08:25 PM
jkeile3
Apr 25, 2019 06:20 AM
Sleeper_Z
Apr 28, 2016 09:21 PM
mnd7775
Mar 10, 2014 04:52 PM
