Coil Pack Harness Connection Order
Old Oct 14, 2019 | 12:14 AM
I DTW I's Avatar
I DTW I
Default Coil Pack Harness Connection Order
I just completed valve cover gasket replacements and have reason to believe I've inversed coil pack connectors. I wasn't sure which one to reconnect where. It's misfiring and running very poorly. The connectors will reach multiple coil packs! Another thread said the EC section of the FSM details which wire color to which coil pack # but that was for the 2007+ and I can't find it in the FSM anywhere for the DE. Can someone take a photo of which connector goes where or tell me where in the FSM the color is detailed?
Old Oct 14, 2019 | 03:24 AM
karlt's Avatar
karlt
The FSMs are available here: https://www.nicoclub.com/archives/ni...e-manuals.html
Old Oct 14, 2019 | 02:05 PM
I DTW I's Avatar
I DTW I
Please read the original post. I said I have the FSM but can't find where it details which connector goes to which coil pack. Thanks.
Old Oct 14, 2019 | 02:11 PM
travlee's Avatar
travlee
Master
You are that guy aren't ya?
Old Oct 15, 2019 | 02:49 AM
karlt's Avatar
karlt
Spoon feed is right. For my 2005 the coil pack wiring diagrams, with wire colors, are on pages EC-691 and EC-693.
Old Jun 6, 2022 | 12:25 PM
Abosse166's Avatar
Abosse166
[QUOTE=I DTW I;11004330]I just completed valve cover gasket replacements and have reason to believe I've inversed coil pack connectors. I wasn't sure which one to reconnect where. It's misfiring and running very poorly. The connectors will reach multiple coil packs! Another thread said the EC section of the FSM details which wire color to which coil pack # but that was for the 2007+ and I can't find it in the FSM anywhere for the DE. Can someone take a photo of which connector goes where or tell me where in the FSM the color is detailed? Bro did you ever figure it out I’m stuck
Old Jun 18, 2023 | 03:47 PM
WAC performance's Avatar
WAC performance
I would try switching coil 4 and 6 around. Or checK for broken wires to the connectors. 🤷‍♂️
Old Jul 12, 2023 | 03:48 AM
zayfromtheA's Avatar
zayfromtheA
Default Thank you all
I’m not sure if you all are active in this thread however I read that I should switch my 4 cylinder and 6 cylinder wires and my car is no longer misfiring !!! I’m very thankful for you all this has been the first car I’ve ever worked on and was discouraged when I tried everything but couldn’t fix the misfire again thank you guys !
eyeSea
Jul 6, 2025 03:13 PM
Hayden Winborn
Mar 21, 2017 10:20 AM
Bilazaurus
Jan 30, 2017 05:45 AM
Redefin3d
Apr 20, 2013 01:13 PM
Merck
Feb 5, 2009 05:45 AM
