Signs of Spark Plug O-Rings Failing
Old Mar 10, 2014 | 03:03 PM
mnd7775's Avatar
mnd7775
Default Signs of Spark Plug O-Rings Failing
So I looked at my driver side valve cover, and there is a good ammount of oil by the seam. I realize that the valve cover gaskets will need to be replaced. I have read up that the plugs' o rings tend to fail also. Short of pulling the plenum and getting in there and looking at the threads on the plugs, are there any other signs that could tell me oil is getting in there. I would rather avoid buying new valve covers if I can for sure know that the spark plug o rings are ok
Old Mar 10, 2014 | 03:21 PM
92K1500's Avatar
92K1500
You don't have to pull the plenum. Just pull the rearmost coil packs out. If there is oil on the boot your valve covers are leaking.
Old Mar 10, 2014 | 04:25 PM
mnd7775's Avatar
mnd7775
Alright thanks, I was under the impression the plenum needed to come off. Ill jist pull the xoils and hope there is no oil.
Old Mar 10, 2014 | 04:52 PM
myfirstzcar's Avatar
myfirstzcar
It's still a pain, but the plenum can stay on.
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
