Can you make a 03-06 350z hood fit a 2007 350z???
Old Oct 2, 2021 | 10:27 AM
angelboy350z's Avatar
angelboy350z
Default Can you make a 03-06 350z hood fit a 2007 350z???
I want this hood so bad but it’s says 03- 06 and I have a 2007 Can this be fitted to. 07
Old Oct 2, 2021 | 12:13 PM
terrasmak's Avatar
It might , some do and others don’t.
it’s like you have to find someone with one who will let you try
Old Oct 3, 2021 | 02:37 AM
zwei_the_c's Avatar
zwei_the_c
Regular
5 Year Member
Could resort to hood spacers... then you'll have gaps.
I think... to make a DE hood fit better on an HR, you'd have to remove the strut tower and the engine cover, again you'd need to test this prior.
Old Oct 3, 2021 | 04:37 AM
jhc's Avatar
jhc
General & Tech Moderator
Some say the new hood was designed for the HR motor. Wrong. If you look at each 07 Nissan hood you'll notice it was a universal look Nissan rolled out over all models.
Old Oct 3, 2021 | 07:22 AM
angelboy350z
Default This is awesome stuff thank you guys for the insight
That’s def a good point I just don’t wanna make $1000+ Mistake but i can work with that
Old Oct 3, 2021 | 07:24 AM
angelboy350z
that’s a really good idea I can probably find one
Old Oct 3, 2021 | 12:48 PM
Ponyryd's Avatar
Ponyryd
The 07 hood is bulged out at the front, so it probably depends what the underside of the hood in question looks like. you could also check how much room you have below your current hood at that point, if it’s a few inches then you should be fine with the earlier hood I would think.
hijack
Aug 23, 2008 01:59 PM
hellnightkid
Jul 30, 2007 07:45 PM
theSTIguy
Dec 11, 2006 07:59 PM
theSTIguy
Dec 6, 2006 11:54 AM
