350z Door Replacement Compatibility
Old 10-26-2021, 04:23 PM
350zTotal
350zTotal's Avatar
Exclamation 350z Door Replacement Compatibility
Is anyone aware if the old 350z (2003-2007 DE) doors are compatible on the new 350z (2007-2009 HR)
I am aware that the interior door trim is missing a cup holder on the DE version but am unsure if this is the only difference.
Would the older door still bolt and plug in to the newer model 350Z?
350z (2003-2007 DE) Door w/o cupholder.
350z (2007-2009 HR) Door w/ cupholder.
Old 10-26-2021, 06:21 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,305 Likes on 905 Posts
Welcome- Nissan did a mild refresh of the Z33 with the late '06-08 model. The exterior doors are the same, but the interior door panels were part of the refreshed package.
Old 10-26-2021, 06:26 PM
350zTotal
350zTotal's Avatar
So the interior would look different but I would still be able to mount and connect their wiring interchangeably?
Old 10-27-2021, 02:23 PM
Freise
Freise's Avatar
The interior is interchangeable. Just a heads up that although the switches and plugs for the mirror, unlock and windows are the same, the trim panel that holds them (in the carbon fiber in the 2nd picture) is also different and you'd need that as well. On the passenger side, you would also need the older specific "oh ****" handle as well.
Old 01-09-2022, 02:02 PM
brad6080
brad6080's Avatar
I'm looking for a replacement outer driver side door handle, and I'm seeing most listings say they fit 07 models up until production date 11/06. Others say fit 03-08. Are they different as well?
Old 01-10-2022, 06:01 AM
dkmura
dkmura's Avatar
The door handles should switch over as well. I've done it on my Z33 racecar, but it's fully stripped inside.
coanan
Exterior
03-17-2012 05:55 PM
lazyduster
Wanted
05-05-2011 10:46 AM
TuningBrasil
03-05-2004 02:11 AM
Quick Reply: 350z Door Replacement Compatibility
