help with no start issue after VB change
on
06 rev up changed valve cover and plugs put everything back together and it will crank but wont start. to me it seems like it isn't getting fuel? will crank but not turn over? we did miss the cam position sensor plug the first time we started it but that was the first thing i looked at when it wouldn't start . any suggestions we are at a loss of where to start we have check every connection we can without pulling the plunem off again that is our next thing tomorrow to pull everything and go back over all the connections this is my sons pride and joy and we have no clue what could be the problem thanks for any help you might give us
Im knew to this forum so I dont have much to help you with. Ive worked on cars for many years just not the Z33 but it can be something as simple as a ground connection. Its just a matter of going through everything again if it means to pull all the stuff off to check under there. Good luck. Keep us updated when you find the cause of this.
