Solid security light, fans on high, crank no start
Old Mar 13, 2022 | 09:41 AM
logan w's Avatar
logan w
Default Solid security light, fans on high, crank no start
I was driving home one day, my car scraped and broke the crank position sensor connector I replaced it and the crank position sensor. But now the car will just crank and not start. Have a solid security light on and the fans turn on full blast. I can’t hear the fuel pump kick on I tested all the relays and fuses but still nothing… Any ideas on what else it could be?
Old Mar 14, 2022 | 07:44 AM
i8acobra's Avatar
i8acobra
When the connector broke, the wires probably touched and fried the ECM. The ECM is very fragile, sending 5 full volts for more than a couple of seconds could have fried a solder joint in the ECM. Fans on full blast is how I know the ECM is done. When the fan control module loses contact with the ECM, it defaults to full blast to prevent overheating.
Old Mar 14, 2022 | 10:16 AM
travlee's Avatar
travlee
Master
Old Mar 14, 2022 | 12:20 PM
Heel Til I Die's Avatar
Heel Til I Die
I guess there's worse that could happen. At least he didn't scrap his bumper on a pull...
Old Mar 14, 2022 | 05:46 PM
logan w's Avatar
logan w
I’m looking for a new ecu now mines says lp and the others I found say u1 is there a difference? The numbers match except for the last four?
riot4144
Nov 4, 2021 06:03 AM
Nolan23
Mar 1, 2016 03:20 PM
Shawn Hancock
May 5, 2015 02:02 PM
team1320350z
Jul 13, 2008 02:09 PM
black_03
Jul 1, 2006 05:21 PM
