2003 Nissan 350z hesitates around 2k and extreme backfire on deceleration
Old Apr 2, 2022 | 09:26 AM
coleroulston's Avatar
coleroulston
Default 2003 Nissan 350z hesitates around 2k and extreme backfire on deceleration
I have a 2003 350z and I’ve had a problem with the car hesitating around 2k then backfiring on deceleration. The problem stops once the car is fully warmed up. I had a P0132 and P0152 code so I replaced the upstream O2 sensors and the codes are gone but the problem is still there. If it helps I have a cold air intake as well as high flow cats and a tomei cat back. Any help would be much appreciated.
Old Apr 2, 2022 | 01:35 PM
Legacy406's Avatar
Legacy406
When did this start happening? I could be wrong but iirc aside from the sensors it could be a faulty wire or running too rich. Someone else hopefully can chime in as I haven't been around this platform in quite some time.
Old Apr 2, 2022 | 03:54 PM
Jeff92se's Avatar
Jeff92se
Double post
Old Apr 2, 2022 | 07:55 PM
Jeff92se's Avatar
Jeff92se
Seems like the cold start program isn’t running and the engine thinks it’s warm when it’s not. The symptoms indicate lean run. Check to see if mag sensor is clean. But make sure the water temp sensor is functioning. Might be two. 1 for th gauge and 1 to tell the ecu what the water temp is. Ie. To control the cold start program.
Old Apr 2, 2022 | 09:00 PM
i8acobra's Avatar
i8acobra
Agree with this. Sounds like it's lean. Could be electronic (temp sensor, MAF sensor, etc...) or mechanical (injectors, pump). If you've got the cash, put it on a dyno with a wideband. Should prove to be lean.
Spike100
Nov 26, 2014 05:55 AM
blazin202
Jul 22, 2014 09:44 AM
rjej0208
Mar 4, 2009 06:44 PM
