03 Enthusiast Manual Swap
Old Apr 7, 2022 | 05:03 PM
Rick_Sancheese's Avatar
Rick_Sancheese
Smile 03 Enthusiast Manual Swap
Hi, all I recently had my 03 z swapped to a 6spd mt and after getting an 04 manual ecu and flashing my vin to it, I had the check engine light come on. I went to autozone to use their code reader and got the infamous U1000, U1001, and also some P codes aswell, these P codes relate to both A/F sensor and O2 sensor. I talked to an educated friend and said that the U codes shouldnt be the cause of the check engine light and can still pass smog with them but the P codes are causing the light. The Mechanic that did the reflashing told me they suspect it being the ECU that is giving the problem. I am not sure as in anywhere I look no one has the P code problem just the U code. also for the swap I kept the AT harness and just wired the clutch safety switch to the IPDM.
Mikem1986
May 8, 2014 12:44 PM
350drft
Jul 30, 2006 10:42 PM
ChrisM
Feb 2, 2004 05:55 PM
