Cooling fan issue, possibly wiring issue?
Old Apr 24, 2022 | 02:22 PM
LNVFX's Avatar
LNVFX
Default Cooling fan issue, possibly wiring issue?
Hey all,
I've been having an issue with my 2004 350z. Basically the stock fans won't turn on, whether it's driving, A/C is on, or in the built in self test mode. I've verified that both fans work by connecting a power wire straight from the battery to the fans. Swapped IPDM and relays, swapped fuses, and replaced the rear engine coolant temp sensor. I'm about to give in and take it to someone who can properly diagnose, but wanted to see if anyone on here had any last ideas that I could try.
Thank you!
Old May 2, 2022 | 06:30 PM
NapZzZz's Avatar
NapZzZz
If you have a multimeter I would break it down into sections. I now you said you've checked the relays, but you can even have new parts fail which leads down a terrible rabbit hole. It's best to check with the multimeter to see if you are getting power to the relays.
I actually had my relay go bad, I believe it was number 3 in this diagram:
It is a strange part to fail, but it does fail. Same thing as you stated, would not come on during the on board diagnostic, but would turn on when power was directly applied.
Sean Chipman
Sep 29, 2020 01:31 PM
anmcneilly
Jan 28, 2019 07:56 PM
Xonatron
Sep 11, 2015 08:29 AM
koren
Aug 20, 2014 07:27 PM
vagel72
Aug 26, 2013 01:25 PM
