Missing 14mm w brace bolt...will it hurt?
Old 01-26-2023, 02:35 PM
thebomb2644
thebomb2644's Avatar
Default Missing 14mm w brace bolt...will it hurt?
So my W brace bent from being lowered and I managed to pull all 10 bolts off and replace the brace..although one of the mounting holes no longer has threads since the nut on the inside of the frame rail broke its weld from being bent and me trying to get a new nut in there. So I got 9 of the 10 bolts back on and am missing the front 14mm bolt. Do you guys think this is going to hurt the performance of the w brace? Since the shape of the brace looks like it relies on bolts to be connected to function perfectly...
Old 01-26-2023, 03:40 PM
icer5160
icer5160's Avatar
Yes, the integrity of the W-Brace will not be the same without one of the front bolts. Probably won't hurt anything driving it like that, but it won't be able to stiffen up the chassis as intended.
-Icer
Old 01-26-2023, 04:02 PM
thebomb2644
Hmm just wondering if there's an easy way to fix it...I don't think a rivnut would work because the mounting hole is not even as well
Old 01-27-2023, 02:01 PM
icer5160
icer5160's Avatar
Best I can think of is to cut out a hole in the frame next to where the nut broke to gain access, weld in a new nut, rust proof the inside area, then weld a patch over the area that was cut, grind it smooth, and rust proof the patch. A competent shop who specializes in vehicle restorations or modifications (restomod) could get this done for you easily. Not sure what it would cost though. There might be an alternative, but I don't think it would be as strong or reliable of a repair.
Good Luck!
-Icer
thebomb2644
12-26-2022 08:22 AM
HudsoN
08-18-2008 02:11 AM
CEO350Z
11-06-2007 03:02 PM
Lawn Dart
04-07-2007 07:12 PM
vice86
08-11-2003 09:07 AM
Quick Reply: Missing 14mm w brace bolt...will it hurt?
