Cat issues
Old Mar 6, 2023 | 09:44 AM
smaaron26's Avatar
smaaron26
Default Cat issues
Hi new to the forum…
I bought some bolt on after market cats..
the flanges are to small bolt on pattern is off.
Am I ordering the wrong cats… anyone else have any ideas what’s wrong
Old Mar 6, 2023 | 10:16 AM
Heel Til I Die's Avatar
Heel Til I Die
Pics might help, but it sounds like the wrong ones. Or it could be as simple as flipping them around or switching sides.
Old Mar 6, 2023 | 10:50 AM
smaaron26's Avatar
smaaron26
You can’t turn them around
Old Mar 6, 2023 | 11:21 AM
travlee's Avatar
travlee
Master
i am pretty sure the header flanges de to hr are different
Old Mar 6, 2023 | 11:58 AM
smaaron26's Avatar
smaaron26
Thank you so much… been scouring the web trying to figure it out..
Old Mar 6, 2023 | 12:56 PM
Heel Til I Die
They are. Probably would have been a better question to ask where you ordered them from and what year Z you have.
Old Mar 6, 2023 | 02:40 PM
smaaron26's Avatar
smaaron26
It’s a 2007 and I got them from exhaust distribution.. the title says base model.. but I was told it has nismo exhaust
Old Mar 6, 2023 | 03:20 PM
travlee's Avatar
travlee
Master
Pics of exhaust
Old Mar 6, 2023 | 04:11 PM
smaaron26's Avatar
smaaron26
I don’t have pictures of the exhaust right now only cats..
Old Mar 6, 2023 | 09:48 PM
icer5160's Avatar
icer5160
You need to make sure you get the VQ35HR compatible cats. The 3-bolt flanges that mate with the exhaust manifolds are different between the DE and HR. The pictures you uploaded are showing the DE version.
Good Luck!
-Icer
Old Mar 7, 2023 | 06:25 AM
smaaron26's Avatar
smaaron26
Thank you all.
Old Mar 11, 2023 | 06:47 AM
i8acobra's Avatar
i8acobra
Also, the 3 bolt flange uses a donut gasket, not that flat thing. Get new gaskets from the dealer. If the aftermarket cats you got don't use the factory style gaskets, you got cheap Chinese cats. Send them back and get proper ones.
Old Mar 18, 2023 | 11:53 AM
smaaron26's Avatar
smaaron26
Default New cats
So I sent back the other cats and now waiting on the new ones. So another question. If the cats have to be for an HR motor does the 02 sensors have to be as well.
Old Mar 18, 2023 | 01:03 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Yes, all four are different between HR and DE. But why does it matter of you’re installing the correct cats and can reuse your existing four sensors?
Old Mar 18, 2023 | 01:24 PM
smaaron26's Avatar
smaaron26
Default 02 replacement
Because I bought new 02 sensors when I bought the other cats and had them switched out but they are throwing a code..
Old Mar 19, 2023 | 06:28 AM
MicVelo's Avatar
Got it. Sadly non-compatible.
Blake Doghyian
Oct 22, 2016 09:29 PM
Doggman9
Feb 9, 2016 05:45 AM
Demonteverde
Nov 13, 2006 10:10 PM
rulalala
Jun 22, 2005 12:27 PM
NISMO_GUY2003
Dec 21, 2004 03:26 PM
