Front sway bar removal
Old 05-02-2023, 03:21 AM
Steinlarger
Steinlarger's Avatar
Default Front sway bar removal
Any tips on removing sway bar bolts that won’t budge with power tools & hand tools? Makes me want to cut the steering arm off.
Sway bar in way of oil pan bolt, leading to difficult oil changes.
EJohn (05-03-2023)
Old 05-02-2023, 04:45 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,096 Likes on 776 Posts
You should still be able to access the oil drain plug with the sway bar in place. Can you post a picture or two?
Old 05-02-2023, 06:07 AM
terrasmak's Avatar
Received 2,309 Likes on 1,663 Posts
Are you doing your oil change on ramps or jackstands ? I remember that the swaybar in a certain position during travel puts it close to the pan
Steinlarger (05-03-2023)
Old 05-02-2023, 11:13 AM
bre240z
bre240z's Avatar
Ive never had this issue when doing an oil change.
Old 05-03-2023, 04:56 AM
tuzzio
tuzzio's Avatar
Did you try hitting it with your purse?
Those bolts seem to tighten themselves as they're going into aluminum but a good size breaker bar should do the trick.
You can always sell the car.
Old 05-03-2023, 01:57 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,284 Likes on 2,336 Posts
advice helps heaps! For my Tommy Kaira 350z
Have you tried penetrating oil soak? If they've never been undone, that's the only way, short of torch heating.
Old 05-03-2023, 09:45 PM
Steinlarger
On jacks..Mounted into the bolts joining onto the front steering arrangement. (Lower steering arm) Lines up underneath the pan bolt.
Old 05-15-2023, 12:44 AM
BeverlyWatson
BeverlyWatson's Avatar
Are you still facing this issue?
Old 07-13-2023, 09:40 PM
Steinlarger
no all sorted now, was very busy at the time.
dudeitsmartin
05-11-2015 10:30 PM
J.$
09-24-2012 12:41 PM
LSX-PWR
02-16-2011 11:29 PM
striker27
10-18-2009 05:52 PM
damnjoel
01-06-2008 12:35 PM
Quick Reply: Front sway bar removal
