My Z won’t start just clicks
So my 2008 Z’s throw out bearing went out so I replaced it myself it’s a upgraded version this whole process took me awhile I’m barely learning but I install everything back in correctly and I’m stuck with this problem that my Z won’t start it has a loud click which is the starter I’ve replaced the starter, battery, terminals and checked all the ground wires and it still just clicks i took my code reader to find a code and the code P0603 came up but I found zero to irrelevant info and I’ve just been stuck with this click and my car not starting no one has this problem I’ve looked everywhere ig I’m the first as far as I’ve seen
ps*I have been hear a weird high pitch noise that I cannot pinpoint idk if it will help diagnose the problem or not
350Z/370Z Tech Moderator
Sounds like your battery is dead but since you replaced it, next thing to check is the ground cable, the fender ground side if you haven’t.
Regards Gregrod007:
Have you tried putting the car in one of the higher gears and either rocking or pushing it to confirm the motor is turning over? There was a time when "push to start" had nothing to do with a button in the dash (LOL).
Peace,
Peace,
