tap into SPEED SENSOR / reading
Old May 20, 2023 | 10:27 AM
Makriluc's Avatar
Makriluc
Arrow tap into SPEED SENSOR / reading
Hi Guys. Installing a Pioneer Head unit with Sat/Nav. I have to tap into the speed sensor signal behind unified meter and a/c amp connector, is this the right wire (between the two red arrows)and the right connector?
TIA
Old May 22, 2023 | 03:52 PM
icer5160's Avatar
icer5160
Check the PIN number labeling on the harness plug. It should be PIN 26. Location: At Unified Meter and A/C amp behind A/C controls in center console. If that's the AC control harness plug and pin #26 (Solid White), then yes that's the correct wire for VSS.
Cheers!
-Icer
Old May 22, 2023 | 04:00 PM
icer5160's Avatar
icer5160
Note: The A/C amp is the little computer box that sits behind the front panel controls. So I suspect your VSS wire is on one of those harness plugs.
Cheers!
-Icer
Old May 23, 2023 | 01:48 AM
Makriluc's Avatar
Makriluc
Do you remember if the connector itself is white or grey?
Old May 23, 2023 | 07:50 AM
bealljk's Avatar
bealljk
Isnt the speed sensor a CAN based data-output?
Is this what your sat/nav is expecting to use?
If you can’t find the right wire let me know and I can look in the FSM - I’ve been around those parts chasing a fuel level sensor issue.
Old May 23, 2023 | 12:03 PM
icer5160's Avatar
icer5160
I did some digging in the FSM. Based on what I've found. It's the GRAY connector (M49 in FSM), pin #26 (white wire). Here's a PIC to help identify the plug.
VSS = Pin #26 on M49 Gray harness plug.
Beall is correct that some of this wiring uses the CAN system for communications. But I think this specific pin/wire is the raw/analog signal that the A/C Amp Meter then takes and converts/interprets into a digital CAN signal on the bus, for example your Multi-gauge LCD in the triple pod above the cubby.
When your install is done, share some pics!
Cheers!
-Icer
Old May 23, 2023 | 12:16 PM
Makriluc's Avatar
Makriluc
Thanks a million. Will do once the job is done
Old May 23, 2023 | 12:22 PM
icer5160's Avatar
icer5160
I stand corrected, this wire is a digital output signal. But this is still the wire you want to tap into for your head unit.
Note: For stereo installation, the VSS wire is usually not a hard requirement, however it does give you more accurate location data when using a GPS/Map application.
VSS Digital waveform example, 5V reference.
More than happy to help! I'll also be doing a stereo install soon on my Z and I'll also need to be finding/using this wire.
Cheers!
-Icer
treimche
Apr 10, 2020 05:29 AM
espitia350
Jun 9, 2007 07:58 PM
Black_zion
May 9, 2007 12:01 PM
