JWT Lightweight Flywheel w/ stock flywheel bolts... Blue or Red Loctite?
Old May 29, 2023 | 04:29 PM
NoLuck's Avatar
NoLuck
Question JWT Lightweight Flywheel w/ stock flywheel bolts... Blue or Red Loctite?
I'm a little conflicted on what Loctite to use when it comes to installing the lightweight flywheel onto the engine, using the stock (but new) flywheel bolts. I've been told to use BLUE Loctite instead of RED and I've also been told to use RED Loctite instead of BLUE. I've looked on other forums for different vehicles to see what they used, and I get the same results. There is A thread on here that talks about it and the majority seem to say BLUE, but it never clarifies what kind of flywheel they're using. Would have to assume STOCK but I'm not sure if that really matters. The directions say to use RED Loctite on both the flywheel and pressure plate bolts. But I just want clarification from those who are running this setup, if they actually went with RED Loctite on both OR did they go against that and use BLUE Instead. In the end, I just don't want to do something that I'll regret later down the road. Installing this flywheel on a VQ35DE (NON-REV) if that helps.
Thanks
Old May 29, 2023 | 05:09 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Holiday weekend advice- blue loctite is just one step stronger than the red version. I wouldn't sweat it too much using either one, just make sure to use a small amount and torque the flywheel and pressure plate bolts to the recommended specs. In the end, if you follow the install instructions properly you won't regret it.
Old May 29, 2023 | 05:16 PM
NoLuck's Avatar
NoLuck
Noted. Thank you for the quick reply.
Old May 29, 2023 | 05:28 PM
i8acobra's Avatar
i8acobra
Other way. Blue then Red then Green. Blue is what I always use. Red is for stuff you intend to be permanent. Green is for when you wanna weld something, but don't have a welder.
Old May 29, 2023 | 05:46 PM
NoLuck's Avatar
NoLuck
That's the one thing I always got confused about when people say, "Red is for stuff you intend to be permanent". Maybe not word for word but practically the same message. When I loosened my Driveshaft bolts, they all had evidence of Red Loctite being used but I was able to get them off using a box wrench and a socket. Only used a little heat on two of the four bolts too. Maybe I'm just taking the words too literal?
Old May 30, 2023 | 02:23 AM
tuzzio's Avatar
tuzzio
There is also orange loctite now, which has the strength of red but the removability of blue.
Old May 30, 2023 | 04:57 AM
Heel Til I Die's Avatar
Heel Til I Die
The installation instructions say to use red. I used red when I did the JWT clutch/FW combo. Torque the FW bolts to 70-75 ft.-lbs and the clutch bolts 30-33 ft.-lbs. Don't overthink it.
Old May 30, 2023 | 06:21 AM
i8acobra's Avatar
i8acobra
"Intend to be permanent" doesn't mean it is permanent, just that you intend it to be.
Old May 30, 2023 | 08:21 AM
iideadeyeii's Avatar
iideadeyeii
I used red. Torqued it to what I felt was right with my hand/gun
Old May 30, 2023 | 09:35 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Given that mfgr says RED, use RED. Red is particularly good in high vibration applications. As Cobra said, it can be removed. Very easily with a lot of heat cycles (or applying heat).
Here ya go...
Old May 30, 2023 | 11:26 AM
terrasmak's Avatar
Red with new bolts ,don’t screw around. Sheered mine off at the track, dealer installed my clutch and probably reused the bolts
Motonejad
Jul 7, 2020 07:28 PM
Mark Vereshchak
Oct 31, 2017 12:31 PM
tig488
Jan 18, 2006 11:20 AM
streetd
Sep 5, 2005 03:47 AM
vibrant
Feb 23, 2005 10:22 AM
