Airlift Compressor Install Locations
Old Sep 12, 2023 | 04:25 PM
Iceburg's Avatar
Iceburg
Default Airlift Compressor Install Locations
I was wondering if anyone has found a different location to install an Airlift compressor besides the trunk? I was considering doing an axle back and installing it where the muffler currently is.
Old Sep 13, 2023 | 08:49 AM
iideadeyeii's Avatar
iideadeyeii
Sure
Old Sep 15, 2023 | 12:31 PM
bmccann101's Avatar
bmccann101
i mounted a single compressor in the trunk where the foam USED TO be.. passenger side.. used a spring loaded isolation kit.. works great.
You can mount most any compressor outside but need to pay attn to air intake and you will get much more physical wear and tear on the item.
Id still run the air intake thru the supplied tubing into the inside of the car, clean air.
Also dont overheat it.
350Zforlife
50
Oct 31, 2017 05:50 PM
k1653d
94
May 19, 2015 11:30 PM
YooiY
Oct 27, 2004 11:56 AM
yoonakron
Dec 18, 2003 06:09 AM
