Vq35de sputters at idle - sputters at top end
on
So I have been chasing this sputtering issue for a while now. I’m going to make this short sweet and to the point so please pay attention as I am very frustrated and would like to fix this issue without dumping a lot of money into unnecessary parts.
ENGINE HAS 52K Miles
at idle the car likes to sputter please review the video within the link attached. When I’m on throttle at top end passed 4000 rpm’s it would sputter and begin to lose power but not stall the car.
https://drive.google.com/file/d/1ceu...w?usp=drivesdk
I thought it was due to a vacuum leak which I heard. I fixed the leak and no changes. I also noticed that my injector O-rings were shot and the bolts on the rail (front 2) were backed out. Probably why my o-rings were ****. So I fixed that …. No change
So far what I have replaced
- spark pulgs… yes I gapped them correctly I double checked
- cylinder 5 injector
- cylinder 5 coil pack (fixed another issue I had)
please help me I’m a little lost. Keep your bs comments to yourself.
travlee (09-26-2023)
on
https://drive.google.com/file/d/1Si-...w?usp=drivesdk
here is another video of inside the car at WOT
Master
iideadeyeii (09-28-2023)
Modern spark plugs such as Iridium or Platinum should not be "gapped" by hand. You can use the gauge tool to check the gap, but do not attempt to modify it, this will result in damage to the electrode tip and ruin the plug. You could cause more ignition problems without even knowing it.
What codes have you pulled? Sounds like you focused on cylinder 5 for a reason. This could be a classic case of failing cam sensors and/or crank sensor, but it is unusual for these to show problems at such low mileage. You would need advanced electrical diag tools (live sample data) to confirm if a cam or the crank sensor is at fault. Always use OEM ignition system sensors for these cars.
Good Luck!
-Icer
Good Luck!
-Icer
on
https://youtube.com/shorts/t8S_xEa20qg?feature=shared
Good Luck!
-Icer
Good Luck!
-Icer
Thank you for the write up.
plugs gapped correctly and gapped with a tool yes.
no CEL so no codes can be pulled.
I did however pull a coil pack on cyl 3 same bank as 5 but has nothing to do with 5 since I gave it a new coil pack and that Subaru boxer sound went away and ran way smoother. But anyways pulled 3 and saw that the electrode was corroded. I sprayed some contact cleaner on it let it soak a little and tried to clean with a rag but seems to be really on there’s (please view attached photo)
Cyl 3 Coilpack
I didn’t have anything that can really clean it like a brush but today at my shop I’ll try a little harder to clean it and see if it makes a difference. My coil boot (boot itself - not the coil) looked to be in good condition. The coil seemed to show signs of corrosion but not as bad. I’m thinking I clean the coil pack and buy a new boot with a new coil
