Mishimoto Fan Shroud Question
Old Jan 7, 2024 | 12:01 AM
Sw1fty's Avatar
Sw1fty
Default Mishimoto Fan Shroud Question
So my radiator crapped out and I bought a Mishimoto MMRAD-350Z-07. For the life of my I can't find a 07-09 Fan Shroud for sale.
Did Mish ever make them for the gen 2?
OEM fans still work fine but I am concerned about the clearance with the new rad being thicker. Does anyone have any experience with using the OEM fans with the radiator and if so how was your clearance on a VQ35HR.
Second part, does the 03-06 fan shroud mishimoto make fit the 07-09 rad?
Old Jan 7, 2024 | 06:02 PM
Aeneas137's Avatar
Aeneas137
The HR engine is not any longer than a DE engine. it has extra camshaft sensors and two more variable controllers but would not affect the radiator or fan shroud. I have a large Mish radiator with the OEM fan and shroud. no problems.
Old Jan 7, 2024 | 10:48 PM
DarkZ03's Avatar
DarkZ03
The Mishimoto fans are not good, they are worse that stock an can cause overheating.
Old Jan 11, 2024 | 01:15 PM
Sw1fty's Avatar
Sw1fty
Yeah, I've decided to stick with the OEM. I did reach out to Mishimoto but haven't heard anything back from them.
Old Jan 11, 2024 | 06:29 PM
icer5160's Avatar
icer5160
The only concern I would have with the Fan Shroud on an HR is the coolant hose routing. Nissan changed this on the HR to accommodate the twin Intake plenum tubing. I don't own an HR, so I cannot confirm if this would pose a problem or not with the shroud. What I can say is that I upgraded my DE's rad to a Koyo performance Rad (very similar to the Mishimoto unit) and although the fitment for the fan shroud is very tight tight, everything does fit snuggly without clearance or rubbing issues. The biggest problem I ran into was making relief cuts in the core support to accept the larger support brackets for the condenser (at the bottom of the radiator).
Cheers!
-Icer
Old Jan 11, 2024 | 11:56 PM
Sw1fty's Avatar
Sw1fty
Cheers!
-Icer
I managed to find a fella that had installed the same rad and oem shroud on YouTube with the VQ35HR. Fitment looked snug also but nothing close enough to rub once everything was back in place. My only worry now is how to install the uni transmission cooler (its an auto), first car and basically learning all this as I go.
350z006
Jul 13, 2023 04:51 AM
John Toves
Aug 12, 2016 06:20 AM
CandlestickPark
Cooling System
Aug 3, 2011 07:34 PM
Zume
Jan 22, 2008 10:39 AM
