Suddenly both doors wont open in and outside
Old Jan 5, 2024 | 10:50 AM
Alex1990's Avatar
Alex1990
Default Suddenly both doors wont open in and outside
Hello, I am Alex and live in The Netherlands. I love my 350z, but a week ago I suddenly had a problem.
On thursday I went for a drive and the car did it great. On friday I wanted to step in the car en suddenly I could not get in the car through the doors. Both on the driver side and the passenger side the door handles does not work. Also not from the inside.
I can get inside the car via the back door. Then I can start the car etc, I can control the windows. But no door can be opened. Not from the outside, not from the inside.
Does anyone has any clue what it can be?
Many thanks!
Old Jan 5, 2024 | 12:15 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Many thanks!
This is going to sound stupid but is the lock switch activated? That is, are the doors locked? Little unnerving that pushing that switch creates a massive safety concern.
Old Jan 5, 2024 | 12:22 PM
Alex1990's Avatar
Alex1990
I don't know if my answer is very dumb, but is the lock switch the switch on the both doors? Those switches move when I use the remote control, but nothing happens.
But indeed, it looks like there is a massive safety lock. So where can I find it..? Thanks!
And is it possible that there is a safety lock on, when I can start the car and everything, besides opening my doors, does work?
Old Jan 5, 2024 | 12:27 PM
Heel Til I Die's Avatar
Heel Til I Die
Alternatively, if you want to go Dukes of Hazzard style (has Daisy and her booty shorts made their way to Netherlands?), you can always hold down the unlock button on the key fob. That will roll the windows down and you can jump in.
But how do I get out???
I'm so glad you asked. Roll your window down and gracefully unfold your body through the window opening while nobody is looking (That last part isn't really necessary, but just personal preference). Put your key in the latch of the door handle and hold it in the lock position and the windows will roll back up.
Who needs doors?
Old Jan 5, 2024 | 12:33 PM
Alex1990's Avatar
Alex1990
Who needs doors?
Haha, I tried it but my remote control don't let me to open the windows. I only can open them when I climbed through the back door and put my key in the ignition.
Old Jan 5, 2024 | 12:51 PM
Heel Til I Die
Maybe the window trick is only a USDM feature.
I think Mic was referring to the manual lock on the handle. This...
When you're inside, and you flip it back and forth and use the handle, does the door open?
Old Jan 5, 2024 | 12:57 PM
MicVelo's Avatar
No, I was referring to these controls...
But can't recall whether they lock out both doors. Hmmm.
Old Jan 5, 2024 | 01:00 PM
Alex1990's Avatar
Alex1990
Tried already that one and that won't solve the problem.
Tomorrow, I will try the other switch.
Thanks for your help!
Old Jan 6, 2024 | 01:25 AM
Alex1990's Avatar
Alex1990
Unfortunately no. Does not do a thing. I hear the door locking and unlocking.. but the doors stay closed.
Old Jan 6, 2024 | 07:05 AM
MicVelo's Avatar
Never heard that one before. Only thing I can think of is that both doors, somehow the latch mechanisms (rods and nylon attachments) have both coincidentally fallen off. And that's a long shot. Or even more remote is that all four releases (inside and out handles) have failed. One scenario is possible, both is a reach.
Bet its something simple. Make sure you post up the solution. Good luck!
Old Jan 6, 2024 | 07:41 PM
Aeneas137's Avatar
Aeneas137
you might just need to open up the door panel and look inside to see what's going on.
Old Jan 7, 2024 | 01:28 PM
Heel Til I Die
I don't think he can remove the door panel without getting the door open.
Well, I guess it's possible but not in the original state. Maybe in a few pieces with holes for weight savings. Because racecar.
Old Jan 7, 2024 | 08:20 PM
Alex1990's Avatar
Alex1990
Thank you all. What a weird problem. Unfortunately that no one recognise it. I will let you know what I found.
Old Jan 8, 2024 | 05:31 AM
Heel Til I Die
The door handle lock/opening mechanism is a fairly simple mechanical design. Anyone who has had the outer door handle fail knows this as you need to disconnect it in order to replace. The outer door handle simply presses down on a bent steel rod which inserts into a nylon bushing and then activates the door latch. As far as the lock, there are two cables that are routed from the inside lock switch (located next to the door handle) and connect to the door lock assembly, Toggling back and forth the manual lock simply engages or disengages the lock.
As Mic mentioned, the chance that somehow there was some mechanical failure in both of the doors at the exact same time is pretty slim. Possible, but not likely. The only other thing I can think of (since it happened in both sides simultaneously) is that both door lock actuators have somehow failed and it is stuck in "lock" (like it's getting a constant signal to stay closed) or something else electrical from the BCM.
Check the two 10A fuses (#21 and #18) in the interior fuse block located above the BCM to make sure those are good.
Check the 40A fusible link in the fuse box under the hood next to the battery (you'll need to remove the plastic cowl to access)
If all of those are good, check the power supply and ground for the BCM as indicated below:
Old Jan 9, 2024 | 08:39 AM
Aeneas137's Avatar
Aeneas137
there is one situation that could have caused both to fail at the same time: someone replaced both of them and did a sloppy job so they both failed after the doors were closed a couple times. this would not surprise me in a quick flip sort of sale. maybe not the case here but could be.
Old Jan 10, 2024 | 11:18 AM
Aeneas137's Avatar
Aeneas137
he said it was just the outdoor handles that don't work. assuming the indoor handles do work.
Old Jan 10, 2024 | 11:35 AM
Alex1990's Avatar
Alex1990
Unfortunately no, I said in my opening message that the handles don't work, not from the outside but also not from the inside.
When I have time, I try to take off the doorpanel. I also hope to check the electrical system.
Old Jan 10, 2024 | 02:03 PM
icer5160's Avatar
icer5160
Do you at least hear the door lock actuators moving when you use your keyfob?
Holding down the lock/unlock button the keyfob should raise and lower the windows. Same for the key in the driver's door. This feature should work regardless of country/region.
From my experience with the door lock system. If one of the interior door lock switches/panels is unplugged from the harness or has suffered a wiring fault, the entire door lock system ceases to function.
As others have stated, I think your best chance to sort this out at this point is to start with fuses and then go from there. I believe you will need to take apart the door cards, this sounds like a wiring or faulty switch. I highly doubt mechanical door handles have broken on both sides. It sounds like the actuators are stuck in the "lock" position and are not responding to or receiving commands to "unlock".
Good Luck!
-Icer
Old Jan 11, 2024 | 04:47 AM
Heel Til I Die
Since the door panels can't be removed without the door being open, you can still remove the switch panel and inspect the lock switch. I suppose it could be something as simple as a failed lock switch. Hopefully that's it since you can't check the door actuator with the panels on.
Or, you may have to bite the bullet and take it to a Nissan Tech who has access to CONSULT-II and they can pinpoint the problem.
Old Jan 11, 2024 | 05:45 AM
JCat's Avatar
JCat
https://my350z.com/forum/maintenance...de-or-out.html
