Stripped exhaust bolt connecting the Y-pipe and the midpipe
Old May 12, 2024 | 10:10 PM
Someone12132's Avatar
Someone12132
Default Stripped exhaust bolt connecting the Y-pipe and the midpipe
Hello everyone,
Recently I bought a new exhaust system and decided to try and install it this weekend. However, I ran into a big problem. I somehow stripped one of the exhaust nuts despite using a 14mm, 6-point socket along with spraying a bunch of PB Blaster to make it easier to break open.
My first line of defense when attacking this stripped nut was using a stripped nut remover and hammering it in. However, this just made it worse and stripped it even more despite it initially gripping well.
I later went on to try and use vise-grips. This did absolutely nothing.
Lastly, I tried using a nut splitter, but I destroyed the tool itself.
Right now, I'm thinking the best option to remove this nut would be to drill out the stud from the other side. I don't really care about keeping the stud as I plan on replacing it. However, before I do this, is there something else I should try? Any help would be greatly appreciated!
Old May 13, 2024 | 03:53 PM
icer5160's Avatar
icer5160
Do you have access to a torch? Getting some heat on it is the best option. Needs to get cherry red. If soaking in penetrant and using a socket doesn't crack it, then a torch is the next best option. Guys in the rust belt usually just go straight to the torch as standard procedure.
What I've done in the past when I didn't have access to a blow torch, was use a dremel with a cut off wheel and slice through the nut about 90%. Then using a chisel and a 4lb sledge, give it a good whack to crack the nut.
Note: Using a dremel with a cut off wheel does risk damaging the stud, but if you plan to replace it anyway, it doesn't matter. In my case, I nipped the threads a bit, but after running a thread chaser over the stud, it was still perfectly use-able.
Good Luck!
-Icer
Old Jun 2, 2024 | 12:39 PM
Someone12132
I did not have access to a torch. However, the Dremel technique did work and I was able to finally get the bolt off! Thanks a lot for the info!
Old Jun 3, 2024 | 06:24 PM
icer5160's Avatar
icer5160
Thanks for the follow-up! Glad it worked out!
Cheers!
-Icer
PerfectDegree
Apr 13, 2012 11:10 AM
Z33Garage
Mar 1, 2012 12:49 PM
whitecel
Mar 28, 2008 11:45 PM
Brocken
Aug 16, 2006 12:11 PM
350Zenophile
Nov 2, 2005 08:56 AM
