Keyless entry remote signal kind of weak?
Old Sep 25, 2002 | 09:26 AM
padam07's Avatar
padam07
Default Keyless entry remote signal kind of weak?
Is anyone having a problem with the signal strength of the keyless entry remote. I have noticed I have to be with at least 15 feet of the car for it to work and even closer for the windows to roll down. I have a 1998 Maxima SE and I can be way over 100 feet away. I would just like to know if anyone else's is the same way. If so it might be made that way. I haven't spoken to the dealer yet but I might at a later time.
Old Sep 25, 2002 | 09:42 AM
blueshift's Avatar
blueshift
Charter Member #83
I've used it from at least 40 feet away....doesn't always work from that far...usually within 30 it's fine.
-Andrew
Old Sep 25, 2002 | 09:45 AM
Mikey Likes It's Avatar
Mikey Likes It
Charter Member #44
Touch the fob to your head; it will work alot farther.
Sounds goofy, I know, but I think your mellon acts like a big antenna. It does work!
Next the activists will be putting diffusion thingys on your key fobs to keep you from getting a brain tumor.
Mike
Old Sep 25, 2002 | 09:55 AM
NissaNZ's Avatar
NissaNZ
Mike
It does help, you're right. I used to have an aftermarket alarm that had a range problem and used to touch it to my chin or head and it helped, lol.
Old Sep 25, 2002 | 11:33 AM
robf's Avatar
robf
Charter Member #70
50-60 feet has been no problem. My Acura hardly ever works from that far away . Sometimes I have to be sitting in it for it to work. Nissan seems much better. Haven't tried the head thing but I am going to!
Old Sep 25, 2002 | 11:46 AM
350z_tako's Avatar
350z_tako
Know it all
mine is pretty strong....
Old Sep 25, 2002 | 11:54 AM
Slareau02's Avatar
Slareau02
A lot of this has to do with electrostatic interference...i.e. if you are next to a powerplant it won't work as well as if you are in the middle of a field. Also weather conditions seem to have an affect on all remotes.
Old Sep 25, 2002 | 06:53 PM
BILZ Z's Avatar
BILZ Z
You know those cheapskates at Nissan are just trying to save some bucks. They put used batteries in your remotes. Put some bunnies in them, touch yourself with the remote, oops, not there, and you'll be just fine.
Old Sep 25, 2002 | 07:18 PM
JeepRage's Avatar
JeepRage
the chin thing sounds stupid, and people think im goofy until i show them it actually DOES work. i live by it
Tochigi_236
Sep 27, 2015 03:40 PM
hardwood66
Sep 8, 2015 04:31 AM
