doing a standing burnout in a stock Z...
Old Apr 10, 2004 | 11:30 AM
orhanz33's Avatar
orhanz33
Default doing a standing burnout in a stock Z...
you know, one of those when you drop the clutch and hold the brake when flooring the car ... i've never tried it in my Z (6mt), but someone at the track told me i need to disconnect the brake fuse? i used to think this was only for the auto Z's i would just go out and try it but i've never done it and if it didn't work i'd probably think i was just doing something wrong i need to start heating up my tires at the track!
p.s. while we're on the subject, how do you do your standing burnouts?
*search is down*
Old Apr 10, 2004 | 01:18 PM
Silverstone_350's Avatar
Silverstone_350
rev to 3500 or higher, dump the clutch, and hit the brakes
yaaaaay
oh yea, don't forget to turn TCS OFF! I kinda forgot to do that yesterday in front of some people, and it wuz kinda embarassing. But once I realized what I did wrong, I just went ahead and did some donuts to make up for the not so hot burnout. Left some nice circles in my school library's parking lot
Old Apr 10, 2004 | 02:11 PM
joe56's Avatar
joe56
can it be done with an AT?
Old Apr 10, 2004 | 02:19 PM
jesseenglish's Avatar
jesseenglish
I've only tried it once at the dragstrip. I did pretty much exactly what you describe and the engine bogged down like it was cutting throttle. TCS was definitely off. I wondered at the time whether 6MT's need to have the brakelight fuse removed also, but I never tried it again.
Old Apr 10, 2004 | 02:24 PM
Melissa's Avatar
Melissa
works for at and mt.....with the fuse in it cuts power by 30% when the brake light comes on......
wouldnt recomend it on the streets ...you have more to worry about when the car behind you slams into your ***....lol
Old Apr 10, 2004 | 02:38 PM
Silverstone_350
in no way am I claiming to be an expert at this, as I've only been driving stick since I took delivery of my Z... but this is what I do
1- TCS off
2- rev to about 3500-4000 (this seems a little high, but I've only done this maybe 3 times so I haven't really experimented yet)
3- dump the clutch
4- hit the brakes
5- give it more gas to make sure that a) you don't stall and b) you make a lot of smoke and leave a nice mark
Hope this helps. I haven't touched my brake fuse at all, so it is possible to do this without disconnecting the fuse. Good luck!
Old Apr 10, 2004 | 02:40 PM
Melissa's Avatar
Melissa
pull the fuse...youll be suprised how much easier it is.....like i stated before when the brakes come on it cuts power by 30%
Old Apr 10, 2004 | 05:02 PM
JimRHIT's Avatar
JimRHIT
Well ... I am able to do one by just dumping it at 4k and spinning away.
Old Apr 10, 2004 | 05:30 PM
gmitro's Avatar
gmitro
Default Brakes
Thanks for the info Melissa. I had a feeling that applying the brakes and accelerator together led to some cut in power. Where did the 30% number come from? Do you think (or know) the 30% figure is independent of how much brake force is applied? Thanks.
Greg
Old Apr 10, 2004 | 08:10 PM
jEzTeR's Avatar
jEzTeR
I wondered what was wrong when I tried to do a burnout.It was wet out and it still spun well but took more throttle than I thought it would.
I revved to 3k or so and dropped the clutch at the track on my last run the other night.I had herd that "Heating your tires" on street tires was just a waste of time and tire.I cut my 60ft from 2.47 to 2.05!So tell me was it all in my head or did the small burnout help?
Old Apr 10, 2004 | 09:54 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
when you said "hit the brakes", do you mean step on the break pedal and hold it or just tap it and let go?
also, when you pull the brake fuse, will the brake function still works?
Old Apr 10, 2004 | 10:10 PM
mapleleafzzz's Avatar
mapleleafzzz
ive, never done one, a brakestand that is, but im going to go out on a limb here and say hold the brake pedal down.......mind u i find the z has plenty enuff to just just drop the clutch and burn away, that tends to keep the local street punks happy enuff
Old Apr 11, 2004 | 06:00 AM
orhanz33's Avatar
orhanz33
what does the brakefuse do? will it automatically work as soon as i pull it? will it automatically serve it's purpose when i put it back in? where/how do i get to it? i only plan on doing this at the track...
Old Apr 11, 2004 | 06:06 AM
Melissa's Avatar
Melissa
yea thats real easy on your drivetrain....see you in the shop when you need a new rear and axles
Old Apr 11, 2004 | 06:09 AM
Melissa's Avatar
Melissa
Default Re: Brakes
Greg
this was all discussed some time ago but since the search is down i figured id speak up....its not based on pressure aplied...its a simple on -off like your brake light switch
Old Mar 27, 2005 | 08:46 PM
unstable's Avatar
unstable
1- TCS off
3- dump the clutch
4- hit the brakes
Yea it does work but it looks and feels like crap... When I've done it I started by rev'n up to 4k and heel toe the brake in, then dump the clutch... all of a sudden the rpm's drop like a brick the SLOWLY start coming up again... it take like 5 to 8 seconds before you actually have your tires spinning at a good rate and get some smoke.
Without the fuse its a totally diff story... Go try for yourself.
Old Mar 28, 2005 | 03:05 PM
Destiny350Z's Avatar
Destiny350Z
I have a AT and I was wondering what would happen if I turned off the TCS and put my Z in Nuetral and rev to 3000 and dropped it in to drive what would happen? Would I get a burnout or a nice trip to the shop?
Old Mar 28, 2005 | 03:24 PM
RED HOT Z's Avatar
RED HOT Z
Quick question when you guys try to burnout does our shifter start to shake violently as your doing the burnout and slowly rolling away the whole car seems to shake
Old Mar 28, 2005 | 06:44 PM
sokudo9l6's Avatar
sokudo9l6
You'll get a burn out if you hold the brakes like what the 6mt does to do a burnout. I seen my friend did it once on his car...i was surprised on how well he pulled it off. BTW that's called a neutral drop...i wouldn't do it too much on a auto tranny.
Old Mar 28, 2005 | 09:14 PM
Destiny350Z
Thank you very much, now I will have to go try it!!
