Oil Pressure???
My oil pressure seems to be all over the map. Does anyone know what the correct readings should be at:
idle?
1st - 6th?
My readings range from under 30psi at idle to 90psi during hard acceleration.
Thanks in advance for your responses.
idle?
1st - 6th?
Your guage is reading just like it should. Remember that the pump is engine driven and (at operating temperature) the viscosity of the oil is constant. What that means is that the faster the pump pushes oil through the system, the higher the pressure it will generate. It's called the Bernoulli principle. Additionally, your pressure at idle will read higher at startup than it will when the car is warm because the oil is thicker when it's cold.
When I first start my car, it idles around 60 and hovers around 90 while driving. After the car has warmed up, it idles around 15 and ranges between 30 and 60 while driving. Your car should behave similarly.
Thx.
