Question about 5AT shifting...
Old Apr 30, 2004 | 10:50 AM
Aggro_Al's Avatar
Aggro_Al
Z- Desperado
Do you power brake without pulling the brake fuse? You need to pull the brake fuse otherwise TCS will limit your power even if the switch is off.
Old Apr 30, 2004 | 11:11 AM
Z-Desperado's Avatar
Z-Desperado
Originally posted by Aggro_Al
Z- Desperado
No I do not so maybe this is a problem to address. Can you briefly tell me where the fuse is that I need to pull is it the actual brake fuse and how will that affect my brakes (no brake lights or what? I know the fuse box is on the left side kick plate but the diagram does not show just TCS but does show the brake fuse? Thanks for your help
Old Apr 30, 2004 | 01:55 PM
Aggro_Al's Avatar
Aggro_Al
Do a forum search under "Brake Fuse" there is a thread with detailed instructions and pictures on how to take the fuse out. Yes, you will not have any brake lights. That's how you will know that you pulled the correct fuse. If you step on both the brake and the throttle at the same time TCS will cut about 30% of your power even if the TCS switch is off. Pulling the fuse will make sure that TCS doesn't come on. Just remember to stick it back in when you're done.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
