Question on 2-1 downshift
Someone said that the 2-1 downshift for the Z is not synchronized. He said I have to come to a full stop before shifting from 2-1 or else there could be problems.
Is this true? Thus far I have been shifting from 2-1 while on a roll without any problems.
Thanks,
Baron
Thanks,
Baron
Probably not true but there's no reason to ever do a 2-1 downshift unless you are stopped. You can get the car moving in 2nd gear from a crawl anyway.
You may argue that sometimes you need the most possible acceleration from, say, 10mph or so but I would argue that you will accelerate faster just fooring in 2nd rather than downshifting to first then back to second within a second or two and wasting all that time shifting back and forth. Plus regardless of syncros, I'm willing to bet you aren't rev-matching very well going down into first on a roll, so you are causing some extra wear.
Originally posted by Jason Bourne
LOL! No, not for those of us who have the manual tranny!
I had to look at the guy's sig to completely understand where he was coming from
Can't you hit the clutch and shift to neutral, let out the clutch, and then give the gas a tap, then clutch and shift into the lower gear without having to worry about the sync's grabbing you....
Why would you try to shift into 1st while moving? 1st gear is for starting off in, period. It's not something you gear down into! That's why they don't put synchros on first. Someone must be doing some very strange things with their tranny to be wanting to do that.
How many of you come to an absolute complete stop 100% of the time? Do you start off from second if rolling slightly???
I double clutch when going into first, reguardless. Anything wrong with that?
