DIY: Dry-cell lightweight battery installation.
Wow im impressed that the battery started the car...I have 2 PC925 sitting in my garage from my previous car. I ran two of them wired in parrallel(high wattage stereo). I couldnt fit both of them like i was able to in my last car and I didnt think 1 would be enough. I'll have to test it out one of these days.
Stock Blose after recall replacement of amplifier is more or less satisfactory to me. Guess I'm not big audio enthusiast.
BTW, I strongly believe that 2 locations for speakers are better than 4 or 6 or 10... more than 2 is good for making a lot of noise, but for true stereo you need 2 sourses. So I keep my rear speakers off. I'd ged rid of them all together, but I'm not sure it'll be easy to sell when I deside to upgrade to newer Z
I agree w/the 2 speaker thing, as do many car audio enthusiasts. Rear fill pulls stage to the back, and basically you don't want that.
But I will need serious power for the Focal Utopias & whatever sub I end up going with .. so I don't think a smaller battery is a solution there.
Than you probably would want something like this
http://www.proudlysa.co.za/about/news/2002/battery.html
Vlad,
Great write-up!!!
How's the lightweight battery working for you (4 months now since you installed it). The battery in my Honda Accord just died, and I plan to transfer my OEM battery from the Z to the Honda, and possibly going with the Hawker Odyssey; although I might try out the PC680 with the metal jacket for additional heat protection.
I did some research too, and the amount of info found is quite overwhelming.
3 Questions for you:
1. Did you have to buy the SAE battery posts ($11) too, or did the battery you ordered come with it?
2. Would you recommend the PC680 over the PC545 if you didn't mind the additional 4 lbs?
3. I guess with these lightweight SLA batteries, the compromise is lower cold cranking amps and capacity. Have you had any issues with that?
Thanks in advance....
BTW, I'm also considering removing my rear speakers. I've cranked my fader all the way back and discovered that the rear speakers barely work at all!?!?!? I believe 90% of the total volume is coming from the front 4 speakers with the fader set on neutral, so unless I have a defective stereo, I think I will remove those rear speakers.
Great write-up!!!
[/B]
[/B]
2. I never have slightest problem with 545, so I don't see need for additional 4 lbs. I just try not to run airconditioning or stereo with engine off. Just as a precaution. I also disconnected light in the trunck (useless anyway) so I can keep my hatch open as long as I wish without warrying.
3. Obviously I didn't run it in the cold yet. But I've read that other people did it and it wasn't a problem on a BMW in cold climate. If I will have some issues I simply will switch stock monster for winter. I don't race in winter anyway.
Originally posted by Vlad
Guess I spoiled somebody's business... $235 is about 135, or 135% more than I paid for parts and battery...
http://www.ntechengineering.com/inde...12&model_id=10
Good DIY on your part, however...
got a question for you.
i ordered the pc545 for i was sent the pc680. it has 135more cranking amps then the 545, but im not sure its needed. it also weighs 2.7lbs more then the pc545. im pissed. the whole point of this thing was to drop as much weight as possible.
should i go through the hassle of returning it and getting a new one (internet order), or should i install it and get over it. hows the battery holding up now, anything new?
thanks
thanks
thanks
thanks
Originally posted by UsafaRice
Shoot Vlad, I need to take a picture of my under-seat installation of this battery to show along with this thread. Hopefully, I get my camera working and can get them up soon.
Stock radio tho, right?
just get a new camera!
The large strip of metal is aluminum. The black on it is PVC tape ("electrical tape") to keep it from cutting up wires and the seats. I have two connections to the negative side. 1 is grounded right on the metal by the seat bolt. The other goes to my grounding kit in the engine bay. The postive connection goes to the same postive fused block in the engine bay. This makes jump starting possible.
Ok, the wires run under the carpet up to the hole in the firewall behind the stock battery location. I only have a Sony head unit. Some silvery, brushed-aluminum looking one with a blue LCD screen and red lights on the other buttons. I used the metra kit, so now I have a pocket for the nitrous buttons and switches to be hidden out of sight.
I also tossed the stock speakers and put in some Sony 3-way somethings up front. It sounds fine for what I use it for (that being, trying not to go deaf). Realistically, the Amuse R1 exhaust will overpower a lot of music anyway.
Tossing all the stock battery terminals and the stock battery tray saved an extra pound. The wires I'm using probably put that back on, but I don't mind. Oh yeah, the wires are out of some kit I bought at Walmart. I wanted some 2 gauge or something stereo power wires, but I couldn't buy them locally for anything reasonable in price. I'm thinking about putting in a little switch to shock the passenger when they annoy me too...
