Passenger window not working - Help!
My passenger window will not roll up. I know the window lock is off and not the problem. Cannot get it to roll up from driver side or passenger side control. Has anyone else experienced this problem? If so, is there a quick/easy fix?
Thanks
Thanks
yep its warranty time
if you get stuck with it down do this
-open passenger door
-attempt to roll window up with door open
-if this does not work close door hard then open again hopefully this will knock it loose and attempt to roll again
-this always works for me if it doesnt for you then your sol
btw i took it in to nissan and there is a tsb for it but 2 weeks later its back again so im going back in. all they did was align the window motor computer?
I've had it, took it to the dealer and got it fixed under warranty....
I don't know if the search is working but try it, there are ton's of threads about this....
In the meantime, try rolling your windows up from the outside by inserting the key into the door keyhole and turning..... worked for me...
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
