"Service Engine Soon" light on after stereo install
Old May 28, 2004 | 06:31 AM
Ant350's Avatar
Ant350
Default "Service Engine Soon" light on after stereo install
Hi all.....I just got my stereo installed....and now on my dash the "service engine soon" light is on....
Being a newbie on car audio...I called the installer and he said that is normal after you disconnect the battery....he said just bring the car to my dealer and tell them the light went on..and they would 'reset' it.....he said just don't tell them that you had any work on the car.
Sorry for the stupid questions..but
Is this normal...?
Do I have to take the car to the dealer?
Can I do it/'reset' it myself?
Thanks all....
Old May 28, 2004 | 07:09 AM
Infern0's Avatar
Infern0
Normal after you disconnect the battery? Ummm no...at least I've NEVER experienced it from just disconnecting the battery on ANY car that I've ever been around.
If you've got a cool dealer, drive it up there and they'll do it real quick on the spot for free (like mine), if not, go to Autozone or a car shop like that and they'll do it for free. Just to find out what the code is. If they messed something up, like crossed a wire (which is my bet) then you'll have something to call them on, then I'd make them go over there wires again.
If, for some odd reason that it came on because of the battery, the computer will try and reset itself to fix the problem, so about after the 3rd or 4th time driving it, with about 30 minutes in between starts...it should go away itself.
Old May 28, 2004 | 07:14 AM
dwg's Avatar
dwg
Default Re: "Service Engine Soon" light on after stereo install
It has happend to me every time i disconnected the battery for more than 10 minutes... The light will shut off after a couple days..
Nothing to worry about..
Is this normal...?
Thanks all....
Old May 28, 2004 | 08:12 AM
Ant350's Avatar
Ant350
Default THANKS
Thanks for the speedy responses all!!
Ant
Old May 28, 2004 | 08:18 AM
wadd3456's Avatar
wadd3456
if you disconnected the little white box the A/C runs controlls attach to, then that is why it did that. After about 10 starts it will reset.
Old May 28, 2004 | 08:23 AM
FairladyZ's Avatar
FairladyZ
It is becuase they disconnected the three guages in the middle of the dash without first disconnecting the negative battery terminal. The dealer will read the code and they will know you had the stereo installed. They should delete the code for free one time only.
On my second Z the light didnt come on because I asked them to first disconnect the negative battery terminal. That worked.
Also when that light comes on it throws numerous codes, and I was told that it may affect performance untill the light is reset. A little loss of power becaues your timing is retarded.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
