Brembo Brakes - Please read!
Old Jun 1, 2004 | 10:41 AM
Zcool's Avatar
Zcool
Originally posted by Jason Bourne
Sharp, it's purely a temperature thing. The pads that you got with the car are designed to provide safe, effective stopping in everyday, street conditions. The Nissan engineers felt that it was more important for the guy in New Hampshire to be able to stop at the end of his steep driveway when he heads out to work on a February morning than for people to be able to do track miles on their Zs. Since no-one had figured out how to make a pad that works well on a cold stop in 0 degree weather as well as working properly at 700 degrees on a racetrack, you're stuck with making compromises. OEM pads are always designed for street usage, even if the car is considered a "sport" or "track" model. Imagine the lawsuits if Nissan installed pads that don't start really working until they reach 300 degrees (like a lot of track pads). THey would be sued out of existence.
But just buy some higher temp pads and you'll be fine. The rest of the brake system (brembo calipers and rotors) is perfectly up to the task of track driving. Btw, John is not using stock pads on the track, either.
Then, if you put racing pads on your car is it unsafe to drive around town?
Old Jun 1, 2004 | 12:42 PM
digerydingo's Avatar
digerydingo
No the car just wont be effective at everyday braking as track pads have a higher opperating temp. For example street pads will be bitting as hard from the time you leave your garage till you get to work and every emergency brake check in between. Track pads are more effective at opperating temp so that cold your stopping distance will be considerably longer then if they where warmed up. During street driving you would never heat your brakes up enough no matter what kind of driving you do, unless of course comming down a mountain run at considerable speed, but between stoplights, traffic and long straight roads your brakes would always cool down too much for track pads to be effective. Basicaly in everyday driving your car with track pads would have worse stopping ability then stock setup.
Noise and rotor wear are other factors to consider. Until track brakes, especialy ones that use ceramic compound on steel rotors, are bloddy noisy until they get warm. By noisy I mean squeal. Head to any club race weekend and for the first two laps you'll easily hear brake squwak and squeal till they are sufficiently warm. Track pads usualy create more friction to = better stopping power which = harsher rotor wear. Now usualy you need to be in temp rage to notice it most but in general track pads are more abrasive and would likely cause premature wear to rotors in everyday conditions.
Relatively new to the market are street/track pads. "Performance pads" have been around for some time but recently new compounds have allowed brake pad manufacturers to make a street/track pad that is actually pretty good a both roles. It's still a compromise and still isn't as good at being a street or track pad but for those on a budget that don't want to replace pads every 3000miles it might be an option. Hell, whatever you decide just remember anything is better then the brake dust the stock pads throw off!
Old Jun 1, 2004 | 12:50 PM
dczoner's Avatar
dczoner
Is it possible to turn slotted or drilled rotors?
Old Jun 1, 2004 | 01:34 PM
apsilon's Avatar
apsilon
Yes.
Old Jun 1, 2004 | 03:13 PM
ChinaClipper's Avatar
ChinaClipper
Originally posted by apsilon
Yes.
A qualified yes - only if you do not exceed the recommended minimum rotor thickness limit!
Old Jun 1, 2004 | 05:19 PM
apsilon's Avatar
apsilon
That goes for all rotors so I didn't think it was worth including but you are of course correct.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
