1/4mile runs
Old Oct 9, 2002 | 01:58 AM
LSs1Power's Avatar
LSs1Power
Default 1/4mile runs
I know the car is still new and all that. But i was wondering who has backed up the magz times of 13.8-14.1 at 100-102? Any 1/4 mile runs? and what mods do u have at the time of the run?
Old Oct 9, 2002 | 11:35 AM
LSs1Power's Avatar
LSs1Power
Anyone??
Old Oct 9, 2002 | 11:43 AM
raceboy's Avatar
raceboy
It's called "search" and I did it for you:
https://my350z.com/forum/showthread....2F4+mile+gtech
Old Oct 9, 2002 | 11:47 AM
95yellovett's Avatar
95yellovett
I think the 13.8 is a little low considering the hp,weight,and
torque of the 350z.With a very skilled driver and powershifting
maybe,but 14.1-14.3 is more like it.
I would love to race one and find out just how quick they
are.
They are killer cars though.
95yellovett(Z07)
Old Oct 9, 2002 | 03:39 PM
LSs1Power's Avatar
LSs1Power
Thats nice, but i wanted real track times. I use Gtech fom time to time to check how much i gained from the mods i added. Anyone ran their cars on a drag strip?
Old Oct 9, 2002 | 04:33 PM
350zhawaii's Avatar
350zhawaii
if you look back I have run the 1/4 mile at 14.3 at hawaii. and I believe...uh..i forgots his screen name, but he run his in Houston with VDC on 14.5 or something like that..do some searching...later
Old Oct 10, 2002 | 03:51 AM
LSs1Power's Avatar
LSs1Power
Do u remember the trapspeed on your run? How high is the track?
Old Oct 10, 2002 | 06:50 PM
350zhawaii's Avatar
350zhawaii
trap speed was at 98...and i'm at sea level
Old Oct 10, 2002 | 06:54 PM
LSs1Power's Avatar
LSs1Power
How many miles the car had at the time of that run?
Old Oct 10, 2002 | 10:44 PM
fdao's Avatar
fdao
If I recalled correctly, it was 500+ miles when 350ZHawaii ran it.
Old Oct 10, 2002 | 11:18 PM
docfrese's Avatar
docfrese
I was also at the track that day and seen him run that time. I seen him run 4 or 5 different times and they got better with each run. That experimenting with the tire pressure must have helped. I also noticed you had alot of wheel spin off the line, once you get that down you should be in the high 13's easy. I happened to have my videocam with me and have you running against that boosted rx-7 that you smoked. What about that silver Supra that was there, beautiful car! Later
Old Oct 11, 2002 | 12:28 AM
350zhawaii's Avatar
350zhawaii
i'm installing Nos since wed..and i'm having problems with it. I called Nos up and they said i had to go with a fogger system instead of a dry system..i'm hoping to get it ready for fri. so i can practice for sat. Docfrese and fdao ...are you guys going to that Monday cruise? hope to see you guys there.
Old Oct 11, 2002 | 12:34 AM
docfrese's Avatar
docfrese
Theres a cruise monday? Whats the time and location? I should be able to make this one for sure. Your hookin up the NOS bro! Damn, your not wasting no time. You going to run it at the track this Friday? Ill be there to watch, later
Old Oct 11, 2002 | 05:51 AM
J Ritt's Avatar
J Ritt
Don't be too upset that people aren't responding...not that many people have even gotten their Z yet, let alone broken them in. I think barring people in warm climates, you're aren't going to see a large pool of time slips until next spring and summer.
I'd tell you my times, but I race around corners at autoX, etc, not in a straight line.
Old Oct 11, 2002 | 06:11 AM
LSs1Power's Avatar
LSs1Power
Ur car isnt broken in yet. U should try it again after 2K or so and see how fast it will run. I'm sure u can hit high 13's. Oh yeah what was ur 60ft on the 14.3 at 98 run? and how big of a shot are u going to use?
Old Oct 11, 2002 | 08:05 AM
MELRUMMY's Avatar
MELRUMMY
Default Old Gezzzzer on Drag Strip
For what its worth, I ran my car at PIR last week with 1400 miles on it. Auto trans, holding shiifts to 6000+. Didn't load the tranny very muchar start, since it was first time on strip and didn't want to damage car. Best run, 14.6 sec. 96.5mph and .62 reaction time.
Not bad for an old gezzzzer on the first run. I'll try it again next spring with more miles on the car.
Keep on Z'n Still jumpin for joy !
Old Oct 11, 2002 | 08:31 AM
Michael-Dallas's Avatar
Michael-Dallas
Originally posted by JDZ
Pull it all the way to redline if you want the best run.
I'd also drop tire pressures to maybe 30psi. This *might* increase your vertical tire contact patch. The factory recommended 35psi tire pressures are geared for corner carving.
If you're really wanna go ***** out, then slap some 15" rims w/ high profile tires and really drop the tire pressures.
Michael.
Old Oct 11, 2002 | 08:42 AM
LSs1Power's Avatar
LSs1Power
Michael.
If someone want to hook up best with the stock tires he should drop the tire pressure between 23-28PSI and pump the air in the front tires to around 40psi.
