Launching 5AT. Just stomp it??
Old Jun 24, 2004 | 01:31 PM
BENJ-AMG's Avatar
BENJ-AMG
Default Launching 5AT. Just stomp it??
Is it bad to just mash the gas all the way to the floor from a dead stop or is it too hard on the car? I've always wondered about this. I know that for tractions sake its usually better to dip in easy at first and once you're hooked up, to bury it. Anybody care to comment?
Old Jun 24, 2004 | 01:49 PM
EL Diablo's Avatar
EL Diablo
Put the Pedal to the Metal if your looking to tear it up
Old Jun 24, 2004 | 02:29 PM
BENJ-AMG's Avatar
BENJ-AMG
So that's a vote for don't do it. Why exactly is it bad? I'm not arguing, I am just curious. Too rough on the tranny, right?
Old Jun 24, 2004 | 02:47 PM
elyliu's Avatar
elyliu
tear it up = go really fast... not literally tearing the car up....
that's how I interpreted it....
just floor it, TCS will dial in the right amount of gas it needs to maintain traction.....
Old Jun 24, 2004 | 06:32 PM
nitrousoxidex's Avatar
nitrousoxidex
haha, don't take everything so literally...
Old Jun 24, 2004 | 07:42 PM
rockinbboy's Avatar
rockinbboy
just floor it. YOu can brake and gas it in to launch. Sure you will wear your brake pads, but not your tranny.
Now, because you are auto...don't put it in neutral and pop it drive while reving. BADDD IDEA....just FYI.
Old Jun 24, 2004 | 09:42 PM
ajk4's Avatar
ajk4
i would recommend turning tcs off. in my experience it tends to over compensate and cuts to much throttle. if you leave it on be prepared to be disappointed; believe me i tried it at the track just for laughs.
Old Jun 24, 2004 | 10:27 PM
luvmyG35's Avatar
luvmyG35
Yes, brake and gas is the best way to launch it. Its called Brake Torque. Keep your left foot firmly on the brake. Then with your right foot, step on the gas and keep your rpm's at about 1500-2000. When you're ready to go just let go of the brake and mash the gas all the way. Now 1500-2000rpm is just an estimate. I haven't tried this on a non-turbo car before so i don't know what rpm is best to do this. I had an automatic Stage 4 WRX and i would bring the rpms as high as the car would allow me to during the brake torque (3000rpm) but this is because i have AWD. With RWD im assuming its different
Old Jun 25, 2004 | 10:50 AM
Aggro_Al's Avatar
Aggro_Al
Stomping the gas pedal on the AT will not hurt your tranny and it does not require any advanced skills. Launching an AT fast is a skill. Learn how to brake torque correctly to get the fasted launch.
Old Jun 25, 2004 | 11:01 AM
genieman17's Avatar
genieman17
neutral...rev...put in drive is called Neutral drop. thats bad...i've seen neutral drops go bad...as in...tranny got dropped...right out of the car...not literrally of course, but a nice trail of metal parts and car making bad noises...not cool dont do it...
Old Jun 25, 2004 | 12:46 PM
shiva's Avatar
shiva
Curious...why would brake torquing wear down one's brakes? Everything is kept at a standstill, after all...
Old Jun 25, 2004 | 01:21 PM
jeffie7's Avatar
jeffie7
It does not wear anything out as long as you're not moving with the brakes being pushed
I use to have a 280ZX Turbo with a 3 speed auto and I would powerbreak the car to about 3PSI I would take it up as high as I could before the tires would break lose Im not sure what RPM it was but as soon as I hit that magic PSI reading I let off the brake and floored the throttle
Old Jun 25, 2004 | 02:11 PM
BENJ-AMG's Avatar
BENJ-AMG
Good. I can gun it guilt free.
Old Jun 25, 2004 | 03:00 PM
theSmoothDome's Avatar
theSmoothDome
I was told that it's a bit hard on the tranny.
Old Jun 25, 2004 | 06:22 PM
luvmyG35's Avatar
luvmyG35
It is hard on the tranny. You are putting stress on it and heating it up pretty good. Do not brake torque all the time because if you do, say goodbye to your tranny
Old Jun 25, 2004 | 07:54 PM
StarcraftBW's Avatar
StarcraftBW
Use your tip-tronic......
Old Jun 25, 2004 | 10:06 PM
ares's Avatar
ares
Veteran
brake stands do heat the torque converter pretty good. it will slip, but it wont like it. at some point in the RPM range itll lock together and youll just start burning out. dont brake launch long, brake, rev, go, as quick as possible.
Old Jun 25, 2004 | 10:07 PM
Shift_350gt's Avatar
Shift_350gt
StarcraftBW thanks for the information, captain obvious.
That is not what he is asking about...
So is brake torque technique bad for your tranny AND brake pad or what? :O
Old Jun 25, 2004 | 11:24 PM
ares's Avatar
ares
Veteran
it doesnt do anything to your brakes. but it is stressful on your tranny. short periods of time it probably wont have much of an effect, if you hold it for an extended time the heat could get to it.
Old Jul 2, 2004 | 11:41 AM
Fresh350Z's Avatar
Fresh350Z
Actually it's only hard on the torque converter http://auto.howstuffworks.com/torque-converter.htm
unless you are power braking in a MT which is also possible, but IMO is a dumb thing to do.
bcoffee20
Nov 19, 2015 06:39 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
