Nissan Emblem Removal Help
Old Jun 25, 2004 | 03:49 PM
mplc's Avatar
mplc
Default Nissan Emblem Removal Help
I found a thread using the search engine but I am still not clear on how to remove the Nissan emblems. I bought the Z emblems from Courtesy and want to install them but I am afraid I will somehow F this up.
Can someone explain exactly how to remove and install the new emblems ??????? The thread I read said to use floss...........I assume they meant to slide it behind the emblem and pop it off, just not sure. The front does not set up like the back does. Is there a different technique to remove it?
Thanks
Old Jun 25, 2004 | 04:07 PM
jeffie7's Avatar
jeffie7
I've yet to try but I've read that you should use a hairdryer to soften up the sticky stuff and then it should come off by pulling it if not use the floss to help get down behind the emblem then after it's off use some goo be gone "local parts place should have it"
I believe the rear hambuger if you have a coupe is held in with revits so if you remove it you will have to fill the holes
however, the convert 350Z is only held on with the double sided tape stuff
Old Jun 25, 2004 | 04:40 PM
mplc's Avatar
mplc
Originally posted by mc350z
are you getting the new emblems they just came out with or the older ones thalt look like the side badges?
just PM me if this doenst answer all your questions
I bought the older ones. I liked the look better than the newer style that will soon be available.
Both emblems they sent me have small pegs on them. I was thinking the rear would also have holes so getting them straight wouldn't be difficult.
The back emblem does not have holes ?
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
