What gas do you use?? 92 or 93 Octane?
I'd like to know what gas you have been using in your "Z".. I have tried both 92 & 93 Octane.. In all honesty, I can't tell the difference except in my pocketbook.. There is about a 8-10 cent a gallon difference in the grades.. I wonder if anyone has tried 1/2 premium and 1/2 regular in your tank yet?? I just went over 2000 miles on the car this weekend and it's running better than ever.. Gas mileage averaged right around 26 MPG on the highway with average speed around 75-80 and a couple of bursts to 100-105..
Steve (k2we) Dobbs Ferry, NY
Sorry I missed the Bob Sharp get togther yesterday..
Well here in CA, the "premium" is 91 octane. It's the highest available in public gas stations. So if you have access to higher octanes, I am sure you can stick to the 92 and you'll be fine. Those in other states (like me) are still using lower octane than you.
Whatever you do....
DO NOT USE ANYTHING LOWER THAN 90 OCTANE
on these new engines. Trust me... I'm on my 4th Z guys & I have tried EVERYTHING!! The best running gas I think is Chevron. It seems to burn the best on a higher HP engine, more so than Texaco or anything else. The second option I think would have to be Shell as the octane is 92 or higer in most states.
I am only voicing my opinion... But if you hear pinging or knocks, try a better gas. ASAP!!!
Zchick
Zchick
Gotta love the cold north baby. 94 Octane from the pump. I know a few cats that have gone down to Cali for some import drags in some serious machinery and where blown away that most gas stops on the way didn't even have 91 octane. Most of the guys couldn't run the first time and the next trip was done with tonnes of octane boost.
In Maryland and Virginia, my preference is
1) Sunoco 260 - 94 Octane
2) Amoco gold - 93 Octane
1969 Datsun 2000 must have 94 or higher, or it will diesel at shutoff, a true indicator of lack of octane.
Holy Cow, you guys must be rich (just Kidding)!
Running my 350Z on 89 here in Oregon/Washington and not a ping or a knock. I've run my last 4 Z's on 87 so I think I'm getting killed with 89. At the first sign of a ping or weak performance I will move up.
The only car I've owned that actually needed 92 was my 1992 SC300 Lexus. Really noticable loss of performance with 89 octane.
Keep on Z'n
Still Jumpin for Joy!
Keep on Z'n
87 Octane in a Z? Jeez, my power lawn mower pings when I use 87 octane. Also. the higher octanes used to have additives (e.g. fuel injection cleaners, etc.) that the lower octanes didn't have - don't know if that is still true.
Originally posted by Zchick
Whatever you do....
Whatever you do....
, 90 is a good low octane to start from.Todd
I'm not advocating the use of 87 for a car designed for Premium. However, running 87 will not, in and of itself, harm your engine. The ECU will use it's knock sensor to detect early detonation and dial back the aggressiveness of it's settings. You _will_ lose power, but you won't cause damage. It seems to me that if you buy a Z, you're buying power and you should follow the MFGs suggestions.
Methanol, however, is a different story. Methanol burns much hotter than good ol' dino stuff, and can cause damage IF run in significant quantities. It's also a lot 'dirtier' than dino in that there are particulates that result from the burn. A lot of the midwest doesn't really have much of a choice, as it's mandated by law [I believe] to have it mixed in in certain states. So, does it hurt if you use the methanol mixed gas? Prolly nothing significant within the first 100k miles, but there are arguments to both sides.
Heck with 92 or 93... has anyone tried 100+ Octane yet? You can get it around here near some local race tracks (you have to put it in containers, they won't let you pump it directly into a street car). I know a guy with a turbo'ed 240SX and he gets an extra 35hp with it (partially because he can run higher boost). And it's just a mere $5 per gallon
I don't have my Z yet but gas in Japan
Regular 95 - 98 Oct
Prem 103 - 107 Oct
Gas on the base about 89 Oct
Cost on base about $1.10
Cost off base $3.50 What a delima
Any body using products like Octane boost?
Regular 95 - 98 Oct
Prem 103 - 107 Oct
Whatever you do....
Zchick
Whatever you do....
Zchick
I do agree w/you on octane, 90 is the absolute lowest grade you want to run and I would not recommend mixing premium and regular unless you have to because you can't find premium. The extra $2-300 a year you save pales when you hole a piston using low octane gas. I define any thing under 90 as low octane if you put it in your Z. In Oklahoma, we can't get Shell, Chevron, AMOCO and 91 octane is about all we can get except for Sinclair and one or two others. The Texaco across the street from the BMW dealer carries 93 octane in N. OKC but its a bit of a drive, but any time I can find higher than 91, I get it.
I have been looking lately, and I was wondering if there are any gas stations in California that you can get gasoline without MTBE, methanol, or ethanol, since the owners manual says to stay away from these additives:
BTW, some 76 stations in the area do carry 100 ocatane at the pump (only 1 that I know of, but you can check their website, look for racing fuel) at $4+ a gallon
- The fuel should be unleaded and have an octane rating no lower than that recommended for unleaded gasoline.
- If an oxygenate-blend, excepting a methanol blend, is used, it should contain no more than 10% oxygenate. (MTBE may, however, be added up to 15%.)
- If a methanol blend is used, it should contain no more than 5% methanol (methyl alcohol, wood alcohol). It should also contain a suitable amount of appropriate cosolvents and corrosion inhibitors. If not properly formulated with appropriate cosolvents and corrosion inhibitors, such methanol blends may cause fuel system damage and/or vehicle performance problems. At this time, sufficient data is not available to ensure that all methanol blends are suitable for use in NISSAN vehicles.
modern engines compensate for low octane. There is NO reason to be concerned about the long term effects. Average power loss from using 87 instead of premium is about %5-8 (15-23HP for Z). Economy is also reduced, making the down grade somewhat less cost effective...
Gasoline comes from very few sources in the world. Gasoline from various different companies have shared space in the same vat at some point in time. IT IS THE SAME GAS. Then chevron adds its techron and texaco techroline etc...detergents that have been proven to add nothing to your life except a higher gas bill.
Believe me. I have to go drink beer now, if you insist on proof cuz your a hard head, then PM me and Ill dig up my sources. Ive been researching for YEARS....
