Bad Brembos?
today as i was driving, i noticed that my brakes squeak whenever i stop.
i have an 03track and it only has 9800 miles on it. i dont drive it hard at all and i dont brake hard at all. so what is this squeak...should i bring it in to get checked out? any help would be appreciated.
thanks guys
thanks guys
thanks guys
thanks guys
Anyways, the dealer should be able to fix it no probs.
Originally posted by LeanerJoe
Have any of you actually looked at the replacement cost of the Brembos???
Prepare to pay about 500 dollars per rotor!?!?!
This is a very common problem. Mine has done it from the first day I got the car. The dealer probably slaps some of the blue anti-squeal goo on the pad shims and calls it a day. If I were you, I'd do it myself. Less chance of something getting screwed up that way!
Mine squeal--but I did that on purpose.
Check your pad thickness, like previously stated, if there's still plenty of pad left, take Dan's suggestion and re-bed them. If it's time for new pads, Hawk HPS seem to be a popular choice for regular street driving, because they grab, but still dust much less than the OEM pads.
It's normal. The brembo pads just glaze the rotor surface that causes the screeches. Just do some firm braking (really firm) from 60 mph a few times after your brakes warm up. That'll cure the sound.
thanks for the suggestion guys.
i'll go out and try some hard stops because i've seen ppl do that in the other "bad brakes" threads.
if there is a problem with the brakes are they covered under the warranty?
It's not a problem with the brakes. It's just the nature of the brake pads. Many performance pads have the tendency to squeak when cold or when they have built up a glaze. If you're really bothered by it, I suggest changing them out for some aftermarket pads. (But honestly, just press the brake firmly once in a while and the problem should go away.)
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
