**2004** Z wheel alignment spec survey
on
Through all of the posts I could not find hardly any discussions focusing on 2004 alignment data results.
With the small % of 04 Z's affected by the feathering, I'm curious to see alignment data from other 2004's.
Anyone who has received an alignment on a 04 Z, please state the what was OUT of spec and value, and please follow the following format, if possible.
**THE FOCUS IS ON 2004 Z's, NOT 2003 Thank you.***
prod date 2/2004
mileage @ alignment 4200
driving type:90% surface/10% freeway
left front camber OUT -1.4 deg
left front caster OUT 7.4 deg
left rear camber OUT -2.1 deg
front toe IN spec 0.06, 0.08
This will require you to know your specs which is in the 350z service manual. Most likely, the alignment service center will not have the 2004 model in their computer. At least the place I went to didn't.
Thanks everyone for contributing.
I apoligize if there was an existing thread with this focus.
prod date 2/2004
on
Re: **2004** Z wheel alignment spec survey
prod date 2/2004
prod date 2/2004
26 views and no feedback......? hmmmm
