Jacking the car
Old Sep 16, 2004 | 09:48 PM
guru_ck's Avatar
guru_ck
Default Jacking the car
Yes I did a search and read tons of threads on how to jack the car up but I still don't understand because my brain is the size of a peanut. I have jacked the car up using the little cut outs but last time I bent them so I ordered so JC Whitney blocks. Can someone show me in this photo where the front cross member is so I know where to place my jack.
Old Sep 18, 2004 | 07:30 PM
elyliu's Avatar
elyliu
I believe it's in the yellow circle, but my jack couldn't get to that spot due to the plastic cover. I just use ramps now...
Old Sep 19, 2004 | 03:02 PM
hndumafia's Avatar
hndumafia
what kind of ramps do you use. i tried using a set of ramps my friend had but my car would not make it up them without the front bumper hitting them. i dont know if it would make that much of a difference but i have the hotckies springs that are like .6 inch drop.
Old Sep 19, 2004 | 04:44 PM
yobri's Avatar
yobri
Rhino Ramps here. You could use some stacked 2x4's (or 2x6's better yet) to serve as ramps if your drop is too low for other alternatives...
Old Sep 20, 2004 | 09:07 AM
spydr's Avatar
spydr
Default Jack points
Here is a diagram
Old Sep 20, 2004 | 09:42 AM
guru_ck's Avatar
guru_ck
Is that red dot for the front jacking point on the plastic part or on the metal U shaped piece shown in my photo?
Old Sep 20, 2004 | 10:21 AM
spydr's Avatar
spydr
The U shaped metal brace
Old Sep 20, 2004 | 10:37 AM
guru_ck's Avatar
guru_ck
Cool, thanks allot! I guess the transmission will ok? Oh and BTW I have heard good things about the Rhino Ramps. You can pick them up at Pep Boys for about $20.
Old Sep 20, 2004 | 11:25 AM
boma's Avatar
boma
nice do the rhino brand fit the z without scratching?
also nice sig pic. that really does the daytona blue color justice.
Old Sep 20, 2004 | 11:29 AM
guru_ck's Avatar
guru_ck
Thanks for the compliment. I haven't bought the ramps yet but I think other people on this board have used them without any problems. Of course if you have your car lower than stock clearance they probably won't work very well.
Old Sep 20, 2004 | 11:54 AM
spydr's Avatar
spydr
Default Ramps
Try these 2 step ramps from california car covers
www.calcarcover.com
Old Sep 20, 2004 | 12:08 PM
kcobean's Avatar
kcobean
Default Re: Ramps
www.calcarcover.com
YOU ROCK!!! My front end ground clearance is about 3" after the Eibach springs and vizage front end.....I've been lookin for something like this. Awesome!!! Thanks!
Old Sep 20, 2004 | 03:43 PM
elyliu's Avatar
elyliu
rhino ramp fits, but barely. If I remember correctly, it was about 10mm clearance (from the slant) before I drove up it.
So is where I circled on my reply the jack spot?....
Old Sep 20, 2004 | 03:51 PM
guru_ck's Avatar
guru_ck
Thanks for the info about the ramps. spydr said the plastic part under the car is not the proper jacking point. He said to use the metal U piece that is under the transmission.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
