Which fuse to pull for burnouts???
Old Oct 4, 2004 | 11:12 AM
SH1FT-Z's Avatar
SH1FT-Z
Default Which fuse to pull for burnouts???
I'm going to be going to the track soon and I need to know which fuse it is that I need to pull in order to be able to do a standing burnout. Pics and specifics would help greatly.
Thanks in advance
peace
Old Oct 4, 2004 | 01:18 PM
zpeed350's Avatar
zpeed350
Default Re: Which fuse to pull for burnouts???
Thanks in advance
peace
It's the one in the manual labeled "Stop Light". Something like the 3rd one from the right on the bottome row. Check the manual.
Old Oct 4, 2004 | 01:56 PM
TtOrMaMnY's Avatar
TtOrMaMnY
what? you have to pull a fuse to do burnouts?
Old Oct 4, 2004 | 02:54 PM
zpeed350's Avatar
zpeed350
My B! I meant the diagram is on the inside of fuse panel cover, pull the one that says "Stop Light".
By pulling the fuse, this will stop your brake lights from working. With the fuse IN, if you hold the brake and give the car full throttle the CPU automatically cuts the throttle to 30%. Making it difficult to do a standing burnout.
If you pull the fuse, the CPU can't tell you are standing on the brake and you can do a brake stand.
Old Oct 4, 2004 | 03:13 PM
zand02max's Avatar
zand02max
He has a Manual, I thought that was only for the auto?
Old Oct 4, 2004 | 03:20 PM
ohw's Avatar
ohw
I assumed you want to go FAST when you are on the track. Burnout generates a lot of smoke with no forward motion, which in turn losses time. Why would anyone do a standing burnout?
Old Oct 4, 2004 | 03:25 PM
zpeed350's Avatar
zpeed350
Throttle cut off happens for the manual also.
I do a standing burnout after the water pit, just before you stage the tree to warm up the tires and clean off all the crap that accumulates on the tires from driving around the pits.
Old Oct 5, 2004 | 11:22 AM
Hazade's Avatar
Hazade
damn I didnt know that
good information man, thanks
Old Oct 5, 2004 | 12:17 PM
roydiculous's Avatar
roydiculous
Not to be ignorant, but if you disable VDC/TCS, what "nanny electronic system" prevents you from doing burnouts?
I thought we could shut the system off 100%.
Old Oct 5, 2004 | 12:21 PM
DrVolkl's Avatar
DrVolkl
Must have something to do with the brake depressed...because I definitely have no problem spinning the tires when I'm going forward.
I shifted hard into 2nd the other day and totally broke loose...I had to let off the gas. I haven't had that happen before...must be the new lighter rims.
Old Oct 5, 2004 | 12:36 PM
zpeed350's Avatar
zpeed350
The fuse must be pulled to do a "BRAKE STAND".
A brake stand is accomplished by pressing the throttle and the brake at the same time. By doing this, the car stays pefectly still while you smoke the rear tires as long as you want.
As opposed to dropping the clutch and breaking the them loose and the car eventually starts moving forward.
Old Oct 5, 2004 | 01:56 PM
teh215's Avatar
teh215
That really does not sound like it is going to be good for the rear brakes especially considering in the next 14 seconds or so you are going to be on them pretty hard. If you really want to do it right I would get a line lock. IF you are not running slicks you may not even be allowed to go through the water box.
Old Oct 7, 2004 | 05:25 AM
j's350z's Avatar
j's350z
A standing burnout looks like this-
Old Oct 7, 2004 | 05:53 AM
zzz350's Avatar
zzz350
I have to admit, "a standing burnout" conjures up a totally different picture in my mind.
Old Oct 7, 2004 | 07:02 AM
Hazade's Avatar
Hazade
if you fully depress the brake pedal it will damage your rear pads. you have to find the happy medium where the front brakes hold the car while allowing the rear tires to spin
doesnt really damage rear brakes, it can do a hell of a job on your tires though
Old Oct 7, 2004 | 07:20 AM
Jetpilot718's Avatar
Jetpilot718
The burnout pad is designed to heat up the traction tires (in this case, the rears). The added heat allows for increased traction for the quarter mile.
Now, on the road course, a similar tactic is used. However, instead of doing a brakestand, the cars will weave side to side, to bring the tires up to temperature - thus increasing traction.
These procedures help you go FAST on the track
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
