Front Coil Over
A 3" drop will do nothing for your Z except upset the suspension's balance... sure you may have a "lower center of gravity" or less body roll, but they're more to a suspension that that. The shocks need to be valved for the spring rate (for your bound and rebound), and the camber, caster, and toe need to be adjusted accordingly.
Originally posted by chicago350z
coilovers shouldn't produce any camber changes. i'd be more concerned with the driving dynamics having only the front end dumped
any car that isnt riding at stock height will have camber problems regardless... if its -.1 to -3degreess... its going to be off the stock setting of under -.05
you gotta remember that the stock camber settings are set more for daily driving and there for they are made for lesser tire wear and better stopping abilities (in general).. the stock suspensions (in general again) are not made for extreme cornering or autox ...
plus what bout camber correction kits, and uprated struts ?
i'm not trying to argue that the car in question is setup for performance its obvioulsy not but i was just saying..
oh and most suspensions today are designed so that as the car rolls, the camber will increase (negativly) to keep the tread square w/ the pavement
not always but moreso than in the past
