does anyone know current alignment
specs for 04 Z? Specifically looking for what the toe in/toe out range should be. If so can you post numbers. I did search but couldn't find it. thanks
well the change for the latest specs that includes the 04 is to be nominally set at .1 mm for toe in.
Here was my alignment results for my 2003:
Toe Results (before alignment):
Left: 0.20 degrees (Out of spec)
Right: -0.19 degrees (Out of spec)
After alignment:
I'm sitting at 0.07 degrees on both sides. The acceptable range was from 0 - 0.08 degrees.
***Courtesy of National Tire & Battery's Laser Alignment***
After alignment:
