Is the "tough" cluth pedal bothering anyone else?
Old Oct 29, 2002 | 09:30 AM
Slexis200's Avatar
Slexis200
Default Is the "tough" cluth pedal bothering anyone else?
Well its not tough, but you need alot of pressure to puch it unlike most cars which are much easier. Is this a problem im having? Or am i the only one who has it. If everyone does have it, is it bothering you? Can we do anything about it? Maybe its just another one of the problems my car has........
Old Oct 29, 2002 | 09:31 AM
ares's Avatar
ares
Veteran
mines very sensitive, I kinda wish it was tougher. but I havent driven a plethora of manual cars, its lighter than my last bmw stick tho. and lighter than a civic or jeep(as I would expect)
Old Oct 29, 2002 | 09:34 AM
6kLaunch's Avatar
6kLaunch
My clutch pedal is VERY EASY to operate. The mecanism in the Z is one of the softest clutch pedals I'v ever had. If yours is hard to press, I would suggest you take it to your dealer and have it checked out. If it checks out OK, then you need to go vist LA Fitness and get in shape.
Old Oct 29, 2002 | 09:46 AM
zPilott's Avatar
zPilott
The only other manual tranny cars I have drived recently are M3's (E30 and E36) and a Jetta, and the clutch on all of them were stiffer than my Z.
Old Oct 29, 2002 | 10:03 AM
Slexis200's Avatar
Slexis200
hmmmm..... Very strange, mine is very stiff, although whats stiff for me may not be for you..... But thats interesting that this was the least stiff, since mine is the most stiff ive ever felt.....
Old Oct 29, 2002 | 10:44 AM
WashUJon's Avatar
WashUJon
That's probably related to the transmission troubles you've described before, Slexis (at least I think it was you, sorry if not). You might have the maladjusted clutch problem that Abyss had. Are you having the dealer look at it?
The clutch in the Z I sat in a few days ago was pretty easy to disengage. My VR-4 had a pretty tough clutch and took much more pressure to press down.
-Jon
Old Oct 29, 2002 | 10:53 AM
John's Avatar
John
If you want to talk about stiff, try some aftermarket clutches with heavy pressure plates... Those things will give your left leg a true workout...
Old Oct 29, 2002 | 10:54 AM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
i think you may want to take it to the dealer to look at it. my clutch is very smooth and easy to operate too, i think its even better than my friend's audi A4 manual.
if you like maybe we can meet sometimes and you can try it on my car see if there is alot of difference.
Old Oct 29, 2002 | 10:58 AM
cotmfk's Avatar
cotmfk
-Jon
I have a VR-4. Although, I do think I will eventually be going in the same direction you went in and pick up a Z from the market.
Old Oct 29, 2002 | 11:00 AM
zwindsor's Avatar
zwindsor
Twisty addict
Very smooth. Just the right amount of pressure.
Me likey
Old Oct 29, 2002 | 12:45 PM
350zSpeedRacer's Avatar
350zSpeedRacer
I had an upgraded clutch in my Camaro SS. Now that sucker gave me a leg work out! Along with the 68 Nova I learned to drive a standard in, I've never come across anything as tough as those two.
I guess I'll find out when I finally get mine, though!
Old Oct 29, 2002 | 12:51 PM
irishfan's Avatar
irishfan
If you are comparing to a Honda Civic clutch, then this one might feel heavy. For a sports car, it is rather an easy clutch. The first time a drove a Corvette, I thought I was going to need 2 feet to keep the clutch down. You may want to have someone with some manual tranny experience give you an opinion, or take it to the dealer to be looked at.
Good Luck!
Old Oct 29, 2002 | 01:11 PM
Aloharacing's Avatar
Aloharacing
It can't be worse than my '84 Accord's clutch pedal!
It takes 40lbs of pressure to depress it.
I never bothered to get it checked out, and became used to it.
The only problem is that my left leg is now bigger than my right.
The clutch itself works fine...
Old Oct 29, 2002 | 03:58 PM
Slexis200's Avatar
Slexis200
Ive really got to try someone elses then to see if im crazy or not.........
Old Oct 29, 2002 | 04:03 PM
rouxeny's Avatar
rouxeny
I dunno, my clutch is pretty light. It's not as soft as say, my 96 Accord, but it's easy to modulate. Almost too easy.
Compare it to say, a Boxster S, and you'll see why those drivers have big left legs. That clutch is STIFF.
Old Oct 29, 2002 | 04:04 PM
NSANY's Avatar
NSANY
Charter Member #52
No complaints here. It's definitely stiffer than the clutch in my 98 Pathfinder, but then again, it IS a sports car. (What did you expect?)
Old Oct 29, 2002 | 04:14 PM
Zmeflyby's Avatar
Zmeflyby
hey u should get ur car checked...
Old Oct 29, 2002 | 06:11 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
where you at in nassau
Old Oct 29, 2002 | 06:28 PM
Slareau02's Avatar
Slareau02
My friend just had a seriously upgraded over-powered ACT clutch installed along with a 11.8 pound flywheel on his 98 impreza rs. You want to talk about something thats hard to depresss, I've seriously had more of a left leg workout on his clutch than I have had in the gym. That thing is ridiculous.
Old Oct 29, 2002 | 06:35 PM
Slexis200's Avatar
Slexis200
Im in cedarhurst and yourself? Can i check ur car out!
