wuts VDC...?
Old Nov 13, 2004 | 03:33 PM
theguykevin's Avatar
theguykevin
Default wuts VDC...?
wuts VDC???
i saw this drifting clip from internet...(350z manual/auto)
and they tested one with VDC on and one with VDC off...
do you prefer if you are getting AT 350z?
Old Nov 13, 2004 | 05:04 PM
kcobean's Avatar
kcobean
VDC stands for "Vehicle Dynamic Control". It's a system that allows the car to apply braking selectively to each wheel as appropriate and/or throttle in an attempt to correct a loss of traction and/or off-line (i.e. vehicle not pointing in the direction it's traveling in) condition. I have no idea how you would drift with this system turned on. In my car with VDC on, if I enter a corner and just step on the gas, the VDC system will literally kill the throttle. I've never gotten it far enough offline that it started braking for me. if I'm in the mood to drive like that, I turn VDC off.
Old Nov 14, 2004 | 08:18 AM
theguykevin
one question...does G35 coupe comes with VDC??? (AT)
Old Nov 14, 2004 | 08:25 AM
NismoKid's Avatar
NismoKid
Kelly, so VDC also cuts the throttle? I thought that TCS controls the throttle and VDC controls only brakes. Thanks in advance.
-Al (owns a Base model)
Old Nov 14, 2004 | 06:15 PM
kcobean's Avatar
kcobean
Al,
That's actually a really good question. I *believe* the answer is that it's the VDC. The reason I say that is because with the VDC system on, my car will automatically reduce throttle in a slip condition, (i.e. I can't drift in a corner using throttle to steer the backend). If I push the button to turn VDC off, I can break the backend loose and throttle steer all day long.
The unknown variable is whether or not turning off VDC also turns off TCS. If so, then I'll bet you're right, it's TCS, not VDC killing the throttle. In any case, that's a darn good question.
Anyone else know the answer to this?
Old Nov 14, 2004 | 08:10 PM
Shahrum's Avatar
Shahrum
I have a question too, I have an 03 touring and on the side of the steering wheel, I have the TCS off button, but there's a blank next to it and no VDC off button. Does this mean my touring model is not equipted with VDC? If so, I can't believe it wouldn't considering the previous owner of my car got it fully loaded (GPS, heated leather, etc.).
Old Nov 14, 2004 | 08:23 PM
340HP's Avatar
340HP
VDC sucks in Nissan / Infiniti cars. It's SO intrusive. I always turn it off, unless it's raining or snowing. But then, I don't drive like an idiot under those conditions anyway.
VDC off is fun in the FX45 on snow. Heh..
Old Nov 15, 2004 | 05:33 AM
kcobean's Avatar
kcobean
That's really interesting. My car ('04 Track) is exactly the opposite. I have a VDC off button, and a blank next to it, where I'll bet your TCS off button is. VDC isn't an "option" per se, that you can opt not to get. It either comes on your model or it doesn't. I really thought the touring models came with VDC, but maybe I'm wrong.
Old Nov 15, 2004 | 06:53 AM
roydiculous's Avatar
roydiculous
Automatics don't have VDC.
The TCS is "level 1 VDC" - it controls wheelspin.
the VDC is "level 2 VDC" - it controls wheelspin and cornering dynamics (yaw control).
The VDC is an improvement on TCS, hence only the VDC button.
Old Nov 15, 2004 | 11:21 AM
theguykevin
k
Old Nov 15, 2004 | 04:56 PM
Shahrum's Avatar
Shahrum
Ahh, gotcha! Thanks for the explanation on that!
Old Nov 15, 2004 | 05:25 PM
340HP's Avatar
340HP
Umm wrong. Both of my 2002 Q45 and 2003 FX45 have VDC, and both are automatic. VCD has nothing to do with the type of transmission. It controls braking and engine throttling. It's a "safety" feature.
TCS on the other hand is only traction control. It's not nearly as sophisticated as VDC. In either case, it's very intrusive, and I choose to disable it under most road conditions.
Old Nov 15, 2004 | 06:49 PM
theguykevin
you disable VDC...i understand for 350z...but y fx45...?
Old Nov 15, 2004 | 08:23 PM
340HP's Avatar
340HP
There are instances, when I'm cornering really hard, and VDC detects slight slippage, it cuts power to the engine and starts braking some of the wheels. Rather intrusive. In theory, you shouldn't need VDC on a 4-wheel drive vehicle. But there it is.
Old Nov 15, 2004 | 08:24 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
completely disabled it and lovin it!
car handles soo much better even when driving in a parking lot slow
Old Nov 16, 2004 | 02:57 AM
theguykevin
oh...
btw for g35 coupe; you cant disable the VDC can you?
i no that 350z can turn the VDC on or off but i heard that for G, you cant turn it on or off.
is this rite?
Old Nov 16, 2004 | 04:32 AM
kcobean's Avatar
kcobean
Errrrr....How'd you do that? Come on....SPILL IT!!!
Errrr....What? You gotta explain that one to me!
Old Nov 16, 2004 | 08:49 AM
The Brickyard Rat's Avatar
The Brickyard Rat
On Zzzzs, all manny tranny models above Enthusiast come with VDC (which includes TCS). The Touring auto tranny does NOT have VDC ...but does have TCS.
Old Nov 16, 2004 | 08:52 AM
Shahrum's Avatar
Shahrum
How come they took VDC off of the Touring model? (the auto specifically) when you can get it then on the auto models below that?
Old Nov 16, 2004 | 09:57 AM
NismoKid's Avatar
NismoKid
There is something you can buy for the Z that's a switch that permanently disables VDC (I've seen the switch usually in the center console compartments). It's been in Japan for a while, but you can get it in the US. I hope Jason chimes in to give more specs on it.
Jason, does your Z now drive more like a Base/Enthusiast when driving slow? What does VDC do when you drive slow? Thanks in advance.
