How-To Drive a 5AT in manual mode
Hey,
I did some searching and found several threads on the notorious switching to manual mode while in 5th and having an auto-downshift to 4th, but I couldn't come across any threads with some sort of step-by-step guide on using a 5AT Z in manual mode for regular driving.
Is this something that can be done? If so, what are suggested shift points for casual driving? I noticed that when you slow down and come to a stop, the Z automatically goes back to M1 (first gear). So does that mean that I never have to tap down (downshift)? Any other suggestions would be great!
Also, if I wanted to slow down a bit when cornering, is it just possible to downshift before going around the corner, and once I'm thru it, upshift? Or will any of this cause damage to the car?
I always drive my TSX and FX45 in manu-mode. I guess it doesn't make sense for someone that hasn't driven true manual. I learned driving on a manual and my first car was a Talon TSI (5-sp manual). Autos make me barf. But wife factor made me get the TSX in auto, and the FX doesn't have a stick option. Thus, the Z.
Shift points in manu-mode are really up to you. If you want to shift in the low-RPM range, you can. If you want to shift higher, you can. That's the whole point of a stick. You control the car, not the computer.
Yes you can down-shift during cornering. Your tranny won't down-shift if it thinks the shift will be above the redline (it's actually lower, prolly around 5000 RPM or so). Thereby thusly henceforth, no damage should result from down-shifting the AT. (My poor grammar was intentional.)
Originally posted by Shahrum
Hey,
Hey,
As far as shift points go, that is up to you. In general, shifting at 2000 rpms or less will get you better mileage. Shifting closer to peak torque will get you more power and shifting closer to redline will give you higher speed in each gear.
I've downshifted before conrners in the manner u describe. I usually wait until my RPMs are low (under 2000) before downshifting, to make sure there's no damage to the car.
Originally posted by BlueDragonZ
I guess that makes sense.
Well I've got a question, is it bad to reach red line in 1st gear?
I wouldn't suggest staying at 6600 in any gear for an extended period, but the VQ engine in the Z has been proven to be bulletproof in stock, naturally aspirating configurations. Redline her all you want.
I love it, People get AT, but want the love of the MT. I drive Boston Traffic everyday (Automatic = a Must), and will prob. be replacing my clutch before i hit 10k miles, but when i jump on 93 North Highway out of Boston, there nothing like slamming gears to 6 and flying!
Oh boy..
Sully
Oh boy..
Sully
Originally posted by roydiculous
Not at all!
Not at all!
Sweet!! That's good to know
Trying to keep on the subject I wanna jump in with a question....
When you do slow down in MM it stays in 3rd till around 10mph usually I just leave it there and accellerate slowly - usually because it is a light and traffic is slow so I cant gun it anyway. Is bad to keep the car in 3 at such a low speed as 15-20 mph when it would normally be in 1st or 2nd?
350Z_Al
Oct 29, 2020 07:44 PM
