2005 track/annv. engine revisions
Old Nov 19, 2004 | 04:00 PM
doc91671's Avatar
doc91671
Default 2005 track/annv. engine revisions
Modifications made to achieve 300hp-strengthened connecting rods and bolts, double mass crank pully, strengthened valve springs, revised piston head shape, new camshaft profile, remapped ecm, valve timing control on exhaust cam, modified intake with shorter and wider runners, revised oil pan baffling, and more.
Old Nov 19, 2004 | 05:38 PM
jnifong's Avatar
jnifong
Default Re: 2005 track/annv. engine revisions
Not to mention the $36K starting price of it. I guess that is what the track model is at alreay?
jon
Old Nov 19, 2004 | 05:40 PM
NY 350Z's Avatar
NY 350Z
i like the oil pan idea
Old Nov 20, 2004 | 01:46 PM
ZPower's Avatar
ZPower
What's the torque spec? Anyone know?
Will the 300HP ever make it's way into all models?
Or is it going to be like the 300Z's Turbo or non-Turbo models?
Old Nov 20, 2004 | 02:12 PM
roydiculous's Avatar
roydiculous
What are your sources? Not to be skeptical.. but it seems there are alot of posts from new posters with just specs - no explanation or source referenced.
Old Nov 20, 2004 | 02:42 PM
alphaz's Avatar
alphaz
he is correct...follow this link http://www.nissannews.com/ and click on the 35th anniversary Z site . Next click on the 35th day....there it is.
Old Nov 20, 2004 | 05:10 PM
jnifong's Avatar
jnifong
alson car and driver has it on their website under the SEMA show
Old Nov 20, 2004 | 08:26 PM
Zexy's Avatar
Zexy
****. That's big work for a little bump of power?
280hp/27g vs 300hp/36g w/reworked everything?
I'll take the first.
Old Nov 21, 2004 | 01:14 AM
xray2's Avatar
xray2
Maybe NNA has something up their sleeve.....hmm.
Maybe the gear ratios are changed too, and their tight-lipped.
Maybe better 0-60 or 0-100 is on it's way.
Old Nov 21, 2004 | 03:36 AM
EnthusiastZ's Avatar
EnthusiastZ
260 lb-ft @ 4800 rpm
Only the 35th and track will have the 300/260 as of now.
Old Nov 21, 2004 | 03:37 AM
EnthusiastZ
Gear ratios have not changed.
Old Nov 21, 2004 | 03:49 PM
Losing Grip II's Avatar
Losing Grip II
so it loses torque? is that what i am seeing? doesnt the 287hp Z have 274lbs of torque?
whats the benefit? is the torque rached earlier?
john
Old Nov 21, 2004 | 04:10 PM
thawk408's Avatar
thawk408
Will this new engine be better for FI?
Old Nov 21, 2004 | 06:14 PM
ZPower's Avatar
ZPower
Thanks for the specs EnthusiastZ. I wonder how the difference feels in the driver's seat. Higher HP, lower TQ = better top end?
Old Nov 21, 2004 | 07:44 PM
ChinaClipper's Avatar
ChinaClipper
At our last Z Club meeting, the report from a test drive of the 300 hp model (in Japan) revealed that the car 'felt' just slightly faster. That was all. The peak power differences and the different rpm at which they are achieved between the two engines probably makes it a small difference as far as the driver's seat feel.
Old Nov 21, 2004 | 08:26 PM
xxmustang11xx's Avatar
xxmustang11xx
Hp, tq, and rpms have a certain ratio. The talk on the new revisions on the 300hp models are that yes it has increased hp and rpm but less torque. It should still be fast with the lack of torque because the word on the street is that the torque will not drop off after its peak as does the 287hp engine does. It will be more usable
Old Nov 21, 2004 | 08:52 PM
doc91671's Avatar
doc91671
The new track engine has lost 14 lbs of Peak torque, however it has higher torque levels in the upper rpm band. The standard engine produces 243.1 pounds of torque at 6200 rpms, while the track/annv. engine is producing 246.2 pounds of torque at 6400 rpms.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
