370z hp/tq from NFS:U
Wtf?!?!!LMFAO?!??! I didn't say my 04 will demolish the 370z. How did you come up with that from my post?? I already know its gonna blow the doors off my Z. Having less torque in a car that's 5 years newer is not acceptable to me. The Hp/Tq difference is of Honda/Acura #'s. 330HP/270Tq???? 60 difference.
Nissan always had that torque advantage all these years. It seems since the 06 Z, the torque is dropping and the Hp is raising. The argument here, is the lack of torque increase for a car that 3 engines ahead of the 6 year DE engine. Its not whether whose engine is the best or whose getting a few more torque in the dyno.
I'm still waiting on those official specs, before totally knocking the idea of having a 370z. I already like how it looks, so, that's not a problem.
Like another poster said comparing stock cars is one thing, but once you start modding, all bets are off. Also, dynos are only good for relative comparisons (Same dyno, same day) and not absolute numbers.
Having said that, there are at least two HRs with intake/exhaust/HFC/tune that are making well over 300whp and 270 tq. I'll see what I can get with the same mods on a my local dyno.
Here's a comparison of my wife's 06 rev-up with mrev2 and spacer, and and my 07 with bassani exhaust only, on the same dyno under similar conditions. Clearly the HR owns up top. At 6500rpms, there's a 40-hp difference!
I am sure the 370 will pwn us all. It's more than just HP and weight - the 350 has problems getting traction. Even with sticky 275's on my car, I can rarely floor it in 1st without wheelspin. I can only floor it on smooth pavement and if my front tires are pointing straight ahead. if Nissan tightens up the rear end on the 370 and makes some gearing changes, it'll eat us alive. Then come mods on top of that. I am going to enjoy my 350 until I can afford a GTR. No use making a jump to the 370 unless it gets a v8 or TT and AWD - I'd call it the 400zx - x for AWD. Then I'd condsider it.
WTF are you talking about. There are full bolt ons for the HR which a couple people on this site have, which will walk your Z. Very limited? What do you have on you DE that I cant put on my hr? TT kits are even out. Congrats your full bolt on Z can walk my stock HR? i guess I should be ashamed LMAO.
Thanks for making my point genious. Only a couple of people have full bolton HR's you say... And the fact is they don't even have "full boltons". What does that tell you? Ding, ding, ding... Very little aftermarket support for the HR compared to the DE? That's right. I know, next you'll say the HR is so great it doesn't need boltons. Ignorance can be cured, but your stupidity cannot. Lol~
Nice but then we present an HR with boltons(which are very few by your own addmission) -- and AUTOMATIC at that. 318whp/264wtq
A manual with not as many mods is at 311whp/270wtq
Thread here.https://my350z.com/forum/vq35hr/3819...os-inside.html
Now go fish!
^ Very nice, but you still get trumped.
Adam from Z1 is making 320whp on his 3.5 NA DE.
https://my350z.com/forum/na-builds/2...soup-nuts.html
Rednezz is at 316whp on his 3.5 NA DE.
https://my350z.com/forum/na-builds/2...ilt-motor.html
__JB with not as much work done to his 3.5 NA DE is putting down 312whp.
https://my350z.com/forum/na-builds/3...g35-coupe.html
Your turn to go fish. :-)
EDIT: Nice try. But I found it.IT does not meet bolt on NA criteria.Meaning not cracking open the engine or heads open.Impressive power but too a whole lot more than the true bolt on HRs presented above.
The 320whp DE is impressive but no where near bolt on as the HRs.Here is the short list of that DE
Its still your go fish.
Internals:
Weisco Pistons (.020 over stock)
Eagle rods
ARP rod bolts
Fully balanced and blueprinted - not only balanced as individual components, but also balanced as a rotating assembly
OE Nissan bearings
Full Ported and polished heads
5 angle valve job (stock Nissan valves)
Tomei 268 cams (268 duration, 10.5mm lift)
NISMO valvesprings
NISMO headgaskets
Lots of time spent porting stock, non rev up lower plenum -we logged over 100 hours between the heads and plenum, going off recommendations from MCR Japan, as well as things we found on our own.
Motordyne 1/4 inch spacer
Unorthodox underdriven crank pulley
New: water pump, rev up oil pump, idler pullies (OEM)
Final Compression checked in at 11.3:1
Fish for what? A stock displacement NA DE is making more whp (at 320whp) than your highest NA HR (at 318whp). I think it's still your turn to go fish. Lol~
Maybe someday there will be more aftermarket support for you HR guys. But it ain't today. :-)
1. .020 bored over in not stock displacement
2. the engine has nonstock cams
3. that engine has massive headwork
4. non stock compression
I can keep going but the point has been made. Yes 320whp from a fully worked DE is impressive but when compared to an automatic HR (318whp)it is not especially when the HR has
1. stock displacement
2. stock cams
3. stock headwork
4. stock compression
I will LOL with you about my own HR Z. It does not meet my expectations even seeing potential results yielded by others. So after 18 months of ownership Im trading it in for an 09 C6 or used 07 Z06 (I hate buying used though). Maybe that will entertain me for a year or two.
FYI: .020 = .004 of a liter. Yeah, it's still considered stock displacement. ;-)
Tell ya what, if you think your HR is so great, go mod it with cams, headwork, etc and come back with some numbers.
Oh, not much aftermarket support for the HR you say? Sorry, can't help ya there. Lol~ :-)
Since modding is not yours-
I have a few more minutes to kill before I go have dinner with a really hot asian chic I just met.
So---- 3498 =/= 3541--We will toss that up to within realm of rounding done by manufatures
Why did you chose to ignore items 2,3,4?
Ive already stated the HR and its potential has bored me after 18 months.I go thru phases and I got a Z car out of my system. Im into asian chicks for
Q4--- are you asian?
Omg, you two arguing HR and DE...Lmao. Who cares? If you bought a Z in the past 5 years youre more than likely capable of buying the 370Z when its out assuming its not TOO much more money. And for the record, i agree with the gentlemen who stated it is disappointing that if true the 370Z will ONLY have AROUND 270 Ft lbs of torque. Its not that it WONT blow the doors off and HR and a DE but the engine evolution isnt what he had hoped given the 6 years of design.
im not taking sides with anyone but i think she left out some of the other parts to prove one of her points which was that aftermarket support for HR is not quite strong yet. i believe there are no cams out for the HR. i dont know bout rest
I completely agree with the members who said throw a turbo on it...that was you are not only surpassing the G's specs but it sets it apart from any other...NOW saying this i know a bunch will be like "that's getting too close to the GT-R" but remember the R35 is a different beast in itself, not only by being a VERY LIMITED production but the potential it has is unbelievable as well as the numbers/capabilities it has NO Z can match that. Slap a turbo on it with low, safe boost to give us that 350whp...this won't raise the cost that much, hell most of the interior will still be plastic! Not only that, you will have many more interested in it instead of a bunch that are back and forth on it
Personally i'd take the rev-matching tranny and engine and put it in my 350Z and be just as happy if not more than the future 370Z owners and have a sexier looking car
/rant
P.S. if you ACTUALLY read the G35 built engine making 320whp, it's a built HR MOTOR
flat out. the new 370 motor will be stronger by far though too. off the block it wont be that much more than the HR motors. the 370's rods are bigger, and stonger, and the pistons are too. they will be able to handle alot more boost and power. around the 500 to 600hp on a stock long block. you guys will see. even with a open deck block. it will take it no problem. but just my opinion, the car looks like crap! that thing is way to damn ugly for me to buy. but the 37 motor will swap right into a HR 350 no problem. harness and ecu and a few hose tweaks, and she is in! also to, for your guys's info, they already make a turbo z from japan from the factory. single turbo setup, with one hell of a ugly intake manifold. im talking about the DE's. they have been around for a while now in japan. just incase you guys didnt know. didnt mean to make that sound all snobby like. but thought i would throw my 2 cents in.
