2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
Forged Performance: A couple of visitors stopped by...
Old Mar 27, 2009 | 08:08 AM
  #61
Kan-O-Z's Avatar
Kan-O-Z
Originally Posted by semtex
Good question. Is the gearing substantially different, maybe? If we start off with two near-identical engines but get different results at the wheels, then I'd think there are some differences somewhere in the drivetrain. In any case, I think we need to wait for some more people to try this setup and dyno their results so that we can compare. Right now, we have a sample size of just 1, and we need more data from a larger sample size. For all I know, maybe I really did luck out and ended up with a factory ringer.
What did your car dyno when it was stock. I think what everyone really wants to know is exactly how much hp was gained with your mods and whether your car is within normal specs.
Kan-O-Z
Old Mar 27, 2009 | 09:19 AM
  #62
semtex's Avatar
semtex
Kan-O-Z
I never dyno'd this car while it was stock. Sharif explained this, and I explained this in the video. That's why both Sharif and I have been saying don't read too much into this, take it with a grain of salt, etc.
Old Mar 27, 2009 | 10:36 AM
  #63
JuJube's Avatar
JuJube
Reminds me of a Dead Stock Dodge SRT-4 I dyno'd when they first came out.
The ridiculous car made 252 HP at the wheels. I had dyno'd about 5 of them in stock trim previously and none came even close to that number.
Congrats to the owner of a Very Healthy 370z!
Enjoy it! I know I would
Old Mar 27, 2009 | 02:46 PM
  #64
shaolin's Avatar
shaolin
Looong time lurker, thinking about getting a 370. I have a question, did you break your car in or did you drive it like you stole it from day 1? I would be curious about how the driver of the white Z broke his car in as well?
Old Mar 27, 2009 | 07:42 PM
  #65
Get_Zwole's Avatar
Get_Zwole
take the 370 motor in a 350 body and that = the perfect car. Sick sick gains ill prob just FI sometime in the near future to fix my bug.
This car will be a beast though.
Old Mar 27, 2009 | 08:23 PM
  #66
Kami's Avatar
Kami
Wow, those are some damn impressive gains! the car sounds amazing too.
Old Mar 27, 2009 | 09:30 PM
  #67
Team STILLEN's Avatar
Team STILLEN
Vendor - Former Vendor
I think you guys will continue to be surprised.. doesn't sound like a ringer to me. This motor is responding well to well designed modifications..
We've got plans in the works.. and I know others do. This will continue to be a highly modified platform, with continued successes..
Old Mar 27, 2009 | 09:47 PM
  #68
hiz-n-herz's Avatar
hiz-n-herz
HR nuthugger here :
Decent gains can be had with HR bolt-ons. I am running 296 whp and 260 wtq with no tune.
But I have to say all you guys getting hung up on HP have the Z all wrong. In particular, it's the increased handling that has me jumping HR ship to get a 370 - that and the syncroRev match. I don't think there's a significant increase in acceleration. Someone's gonna get a deal on my HR - resale has tanked
My stock HR baseline run:
My HR with Injen CAI, Stillen HFC and Bassani exhaust:
Old Mar 27, 2009 | 09:49 PM
  #69
Blck350z's Avatar
Blck350z
.... i think the ecu is totally different in the VHR???? b/c with the VVEL it eliminates the need for throttle body's and I know that has a big effect ( sensor wise ) on how the ecu operates...
That would be interesting though if you could just swap the heads on the HR to VHR heads w/ out also changing the blocks internals...
Does anyone know what compression the 370's are at???
Old Mar 27, 2009 | 10:05 PM
  #70
Nexx's Avatar
Nexx
Originally Posted by hiz-n-herz
HR nuthugger here :
please do not compare you Dynojet numbers to Sharif's Dyno Dynamics numbers. His Dyno Dynamics reads around 8 to 10% less then your typical Dynojet. your 26Xwhp dynojet numbers would have translated to 23X on his dyno.
Old Mar 28, 2009 | 05:47 AM
  #71
Kan-O-Z's Avatar
Kan-O-Z
That's not his point. His point is that he also saw substantial gains on a 350Z with basic mods. It doesn't matter if Dynojet numbers are off. What is important is how much he gained. He gained 30+hp. This fact is true, Dynojet or not!
Kan-O-Z
Old Mar 28, 2009 | 11:39 AM
  #72
Spork's Avatar
Spork
WOW.
Thanks Sharif for showing these results.
Old Mar 28, 2009 | 05:25 PM
  #73
daryl.blas's Avatar
daryl.blas
Thumbs up
Kan-O-Z
^ I was about to say the same thing.. We're talking about number-ratio increases, not just numbers... I too want to jump to a Z34 for the handling factor too.
Old Mar 28, 2009 | 07:20 PM
  #74
semtex's Avatar
semtex
I tried to do the 'keep it below 4000 rpm' thing but really just couldn't. I ended up driving normal, which for me means that I usually shift at around 5000 rpm. I did make a point to not drive it hard until the 1200 miles were up though (i.e., no WOT to redline). I did take it up to redline during the test drive though, and I should also mention that it already had 20 miles on the odo when I bought it, so who knows how it was treated during those first 20. Finally, I don't know if this could be a factor at all, but as I work from home it took me quite a while to complete my break-in miles (about 2 months). Mike took a lot less time to complete his break-in cycle. And he was also more successful at not going above 4000 rpm (which is what the manual instructs). So in short, I wasn't as gentle with the rpms, but my break-in period lasted much longer. The other car was broken in more gently on the rpms, but completed the 1200 miles within a much shorter period of time.
Old Mar 28, 2009 | 07:56 PM
  #75
ChuckD05's Avatar
ChuckD05
Why is the 370z TQ numbers so low ?
Old Mar 28, 2009 | 10:49 PM
  #76
Nexx's Avatar
Nexx
no... if you read into it, its sounds as if the only reason he wants to migrate to the 370z is for the handling only. he fails to mention that the 370z has around 20 to 25whp on the vq35hr.
Old Mar 29, 2009 | 12:24 PM
  #77
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
291whp on the heartbreaker?!??!!?! WOW! calling all HR nutthuggers to downplay this.. calling solo350znub... calling solo350nub.
291 modded, great. We have HR's running over 310rwhp with bolt ons as well. What is your point? The HR loves mods. Get over your HR envy.
Old Mar 29, 2009 | 12:26 PM
  #78
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by Chromex319
wow what a fool
When you research the cars, you will see also. 10 rwhp was on one dyno between both cars, others showed up to 25rwhp gains between both cars. Either way the 350z is lighter, and the 350z has more tq.
Old Mar 29, 2009 | 12:28 PM
  #79
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by blasian
I'm still curious because he said the 350Z base is lighter than the 370Z base but not according to Nissan's words
300whp+ on a DD after exhaust mods and tune is just sickening to me
Nissan misled everyone and this has been talked about on here. C&D actually weighed a BASE model production 370z and it was 3350 lb. That is heavier than my NISMO 350Z.
Old Mar 29, 2009 | 12:29 PM
  #80
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by JAM3Z
Solo is a fool, is this news to anyone?
Maybe a fool that actually has the facts but I have yet to be proven wrong.
