2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
rev matching..
Old Nov 12, 2010 | 11:58 AM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by IBMark
On the street, you could also downshift to lengthen the life of your brakes.
Mark
At the cost of clutch and engine wear. Brakes are a lot cheaper to replace.
Old Nov 12, 2010 | 12:02 PM
007|350Z's Avatar
007|350Z
I can replace brakes in less than an hour for a few hundred dollars. The numbers are a tad higher for the clutch, and a major hassle. Downshifting has its place, but I rarely use it for daily driving. IMO
Old Nov 12, 2010 | 02:08 PM
Zian's Avatar
Zian
+1. Although there are times on the street where I'm glad I downshifted...because I need to hightail it away from yet another creative LA driver. But Brakes are definitely cheaper than clutches, transmission and engine wear...
Old Nov 12, 2010 | 02:36 PM
IBMark's Avatar
IBMark
IB Staff
For sure.
If you rev match correctly, though you hardly put any wear on those components at all.
Just the same, the brakes are designed to stop the car. Using them is a much better choice.
Old Nov 12, 2010 | 02:47 PM
DavesZ#3's Avatar
DavesZ#3
^^ True - smoother gear changes will reduce the shock and stresses on the drivetrain. I haven't spent enough time behind the wheel of a 370 to decide if I like it or not. Seems like a good idea - depending on the implementation and execution.
Old Nov 12, 2010 | 02:54 PM
IBMark's Avatar
IBMark
IB Staff
Personally, for me. Using an auto rev match is kinda like bowling with the bumpers up. I bought a standard because I enjoy controlling the car.
That said, I'm sure it's pretty fun to play around with.
Old Nov 13, 2010 | 09:45 AM
BoomerZ33's Avatar
BoomerZ33
some guys see this innovative feature as a convenience while others consider it a restriction to reduces the complete driving experience.
Old Dec 19, 2010 | 04:17 PM
hellsy's Avatar
hellsy
Originally Posted by vashuba311
Do you like it? I honestly like the challenge of doing it myself. plus i heard it eats gas more.... anyone else..?
I personally like the idea. However i have not had a chance to test it myself. But it does make sense that it will increase the gas consumption. You are increasing the load on the engine even when you are down shifting [going from higher gear to lower,increasing the engine speed]. You can even try this on your 350Z. On your next fill-up, whenever you are slowing down put it on neutral and slow down. After you experiment this, try to rev-match on the next fill-up. You will see a significant difference.
Old Dec 20, 2010 | 08:36 AM
RedBullRR's Avatar
RedBullRR
I love this feature on my 370Z. I also love that you can shut if off.
