VDC on Roadster
Old Dec 13, 2004 | 07:25 AM
maybeZorNot's Avatar
maybeZorNot
Default VDC on Roadster
I'm confused. I have seen several threads that mention that the ZR does not have Vehicle Dynamic Control VDC. Niisan's website
http://www.nissanusa.com/vehicles/Mo...120017,00.html
(Then select the Touring Roadster)
lists the VDC as a standard feature for the Touring Roadster. I called NNA and they tell me that it is a feature included in the 05 Roadster.
Is this correct? or they are just telling me "what I want to hear"
Thanks for your help
Old Dec 13, 2004 | 09:20 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
I have the 05 Roadster and they DO NOT have VDC.
Old Dec 13, 2004 | 09:30 AM
Du4L337's Avatar
Du4L337
I far as I know, only Gran Touring Roadster has VDC.
You can confirm that on Nissan website. Try build a touring raodster or view a spec on standard equpment. For Enthusiast and Touring Roadster you will see TCS as standard. You will see VDC as standard on Grand touring roadster.
Hope that helps.
Old Dec 13, 2004 | 11:05 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
yup..only TCS. BTW, what is Gran Touring Roadster? haven't heard of this model.
Old Dec 13, 2004 | 11:52 AM
Du4L337's Avatar
Du4L337
Check it out here.
Nissan website
Old Dec 13, 2004 | 12:14 PM
maybeZorNot
Originally posted by Du4L337
Check it out here.
Nissan website
Please see a screen shot from Nissan, Touring Roadster selected. Youu will see the VDC option.
Thanks
Old Dec 13, 2004 | 12:23 PM
Du4L337's Avatar
Du4L337
Thanks
That screen shot is misleading, because it shows "key features" for both coupe and roadster. When you click on the coupe / roadster link it only swaps picture not the text.
Below is the complete list of standard features on 2005 Touring Roadster found in "Design and Locate" section
Standard Features
Mechanical
VQ35DE 3.5-liter DOHC 24-valve V6 engine
287 hp @ 6,200 rpm
274 lb-ft of torque @ 4,800 rpm
Emissions - LEV
Continuously Variable Valve Timing Control System (CVTCS)
High-flow intake system
Nissan Direct Ignition System
Platinum-tipped spark plugs
Electronic drive-by-wire throttle
Longitudinally mid-mounted front engine/rear-wheel drive
6-speed close-ratio manual transmission
Carbon-fiber composite driveshaft
Viscous limited-slip differential
Traction Control System (TCS)
17" x 7.5"/8.0" (front/rear) 7-spoke aluminum-alloy wheels
P225/50WR17 (front) and P235/50WR17 (rear) high-performance tires
Tire Pressure Monitor System (TPMS)
Front: Independent 3-link aluminum-alloy suspension with strut bar
Rear: Independent 4-link aluminum-alloy suspension with strut brace and aluminum-alloy subframe
Front and rear stabilizer bars
Ripple-control shock absorbers
Engine speed-sensitive power-assisted rack-and-pinion steering
Power-assisted brakes - 11.7" x 0.95" vented front discs and 11.5" x 0.63" vented discs
4-wheel Anti-lock Braking System (ABS)
Electronic Brake force Distribution (EBD)
Brake Assist
Exterior
High Intensity Discharge (HID) xenon headlights
Dual exhaust tip finishers
Dual power heated outside mirrors
Aluminum hood
One-touch rear trunk release
UV-reducing solar glass
Power convertible soft-top with glass window
Rear glass wind deflector
Electronically moving storage cover
Interior
Automatic Temperature Control (ATC)
3-bay gauge cluster (trip computer, oil pressure, and voltmeter)
Trip computer with multiple displays
Shift up indicator light (manual transmission only)
Power windows with one-touch auto-up/down feature
Partial-down window mechanism
Power door locks
Remote keyless entry with rolling code protection
Remote front windows down
Remote hatch release
Key-operated front windows up/down
HomeLink® Universal Transceiver
Cruise control
Retained accessory power and battery saver
Map lights
Tilt steering column with integrated gauges
Power passenger seatback fall-down lever for driver
Variable intermittent windshield wipers
Auto-dimming rearview mirror
Dual illuminated visor vanity mirrors
Digital clock (in radio)
Two 12-volt DC power outlets
Three cup holders
Dash-mounted storage (N/A with Nissan Navigation System)
Padded center console and coin holder
Rear parcel boxes (2; 1 with Nissan Navigation System)
Seating and Appointments
Perforated or ventilated leather-appointed seats
Power front seats
Heated seats
Driver-shaped bucket seat (N/A with ventilated Burnt Orange Leather)
Passenger-shaped bucket seat (N/A with ventilated Burnt Orange Leather)
Passenger seatback pocket
Driver's and passenger's side knee support
Leather-wrapped steering wheel
Leather-wrapped shift ****
Leather-wrapped parking-brake lever
Cross-drilled aluminum pedals
Audio
Bose® digital audio system with AM/FM/cassette/in-dash 6-CD changer (240 watts)
Seven speakers, including 10" Nd® subwoofer
Radio Data System (RDS)
AudioPilot™ noise-compensating technology
Safety and Security
Dual-stage supplemental front air bags with seat belt sensors
Driver and passenger side-impact supplemental air bags
3-point ALR/ELR passenger seat belt system
Child-seat anchors
Energy-absorbing steering column
Zone Body construction with front and rear crumple zones
Pipe-style steel side-door guard beams
Hood buckling creases
Nissan Vehicle Immobilizer System
Vehicle security system
Old Dec 13, 2004 | 12:47 PM
maybeZorNot
lazy web developers...
Old Dec 13, 2004 | 12:48 PM
Du4L337's Avatar
Du4L337
You calling me lazy....
LOL.. you must mean "web designers"
Old Dec 13, 2004 | 01:03 PM
maybeZorNot
Exactly, web designers. Just spend a little more time and get the specs right... and of course, Nissan will tell you anything just to sell the car...
Old Dec 13, 2004 | 02:58 PM
maybeZorNot
Ok, No VDC. One last question. Do you guys know if the Grand Touring 35 Aniv. Edition will come on any other color besides yellow?
Thanks
Old Dec 13, 2004 | 02:59 PM
Du4L337's Avatar
Du4L337
Silverstone, Ultra Yellow, Super black
Old Dec 13, 2004 | 03:03 PM
Du4L337's Avatar
Du4L337
err... that's for 35th anniversary...
For Grand Touring Roadster, I don't think they ever specified colors...
Old Dec 13, 2004 | 03:06 PM
Du4L337's Avatar
Du4L337
35th anniversary is coupe only, and Grand Touring is like a Touring roadster plus Track equipments like brembos, VDC and track rims and tires. It still has the same 287hp engine, not the 300hp one...
Old Dec 13, 2004 | 03:08 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
man, why waiste time to search on nissan? i had the Roadster and i know for sure i don't have VDC unless they hide it somewhere under the engine.
Old Dec 13, 2004 | 03:14 PM
maybeZorNot
Du4L337 thanks for the info. You really seem to be up to date on the "Roadster". Do you have any idea how much $$$ will it be?
Old Apr 7, 2005 | 01:55 PM
Hupperware's Avatar
Hupperware
05 Gran Touring has VDC and Brembos... $41K
Old Apr 7, 2005 | 04:04 PM
ws350's Avatar
ws350
According to kbb.com, the invoice price, with destination charge, for a 2005 grand touring roadster, is $36,833, or $39,780 retail. Manual trans. only.
As for colors, if you try to "build" a grand touring roadster at nissanusa.com, white and blue aren't offered as exterior colors, and the frost interior isn't offered.
Old Apr 8, 2005 | 05:05 AM
koolyce's Avatar
koolyce
Well in Canada the Grand Touring is offer in all the color and start at 55 498$ Can.
http://www.nissan.ca/en/buying/confi...elCode=Z3GG55#
Now they need to make a 350zx (x is for the all wheel drive system).
Old Apr 10, 2005 | 09:08 PM
DRE350's Avatar
DRE350
Hi guys. I have an 05 Roadster and I have VDC and Brembos. Maybe we get different spec cars in OZ.
